Power up the pc and see if the fans are working. If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
setup shows SATA H/D is seen by system but I can not access it to partition or format the disk. I am...
(More)
setup shows SATA H/D is seen by system but I can not access it to partition or format the disk. I am running windows KP. Ihave tried to set it up by using the CD and the other H/D. Both H/D's are 500 gig memory. Mother board is MSI G31m3 v2
i have a laptop. i want to take a backup of my system state(asr) and all data.how it is...
(More)
i have a laptop. i want to take a backup of my system state(asr) and all data.how it is possible.please help me. configuration intel(r)core(tm)2 duo cpu t5450 @1.66ghz 983mgh,1.87 gb of ram
Bij het opstarten van mijn pc doet mijn scherm het niet meer, kabel en scherm zijn n orde want bij...
(More)
Bij het opstarten van mijn pc doet mijn scherm het niet meer, kabel en scherm zijn n orde want bij aansluiten op mijn laptop doet het scherm het wel kan het liggen aan het moederbord P4I45GV.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
