Question about Refrigerators
Water dispenser lg gr-602tvpf
My water dispenser is making the noise as if it wanted to make the water goes out but when you push the bottom the water doesnt comes out. the noise that makes is moreless like the bomb that normally u hear whn u push the bottom to let the water go out but now is not working, what can be the problem ????
Re: water dispenser lg gr-602tvpf
The water line is froze.. I took a hair dryer and applied it directly to the dispenser for about 10 minutes. I then held down the buttton for approximately 30 seconds and the water began to drip extremely slowly then faster until a small chunk of ice shot out of the dispenser. I believe the reason this happened was that I the temp of my freezer set lower than the fatory setting.
Posted on Jan 06, 2008
0 characters
3 Points
LFX25970 Bottom Freezer Refrigerator This morning it began to make a clicking noise coming from the ice/water dispenser and cold air was coming down from the opening. I pushed the lever for ice and it...
You may have an issue with one or more of the following:
* icemaker
* dispenser actuator
* ice chute door assembly
* ice dispenser solenoid (if the solenoid is stuck in an open position, the ice chute door/flap would remain open allowing cold air to escape).
Contact an appliance service company.
Feb 16, 2010 | LG Refrigerators
Water dispenser does not work on my lg refrigerator. Water only trickles out a little. Ice maker isn't working either.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad. GE makes a heater that will prevent this from happing again. The part number for this heater is WR49X10173.
Jan 23, 2010 | LG LRSC-26922 Side by Side Refrigerator
Where to get bypass plug/cap for LG Refrigerator
is there a way to bypass the filter on a lg refrigrator?
Jan 07, 2010 | LG LFD21860ST Stainless Steel Bottom...
No water, no ice-LG LFD21860ST
Sound like a water supply problem, as both get water from the same source. Both valves are connected to the water line that supplies water to the frig, in the back, bottom, behind the cardboard cover. Make sure the water valve is on for that line. The noises indicate thew valves are probably working, but are not getting any water.
Sep 19, 2009 | LG LFX25960ST Stainless Steel French Door...
LG fridge freezer GR-L207QVJA. The ice dispenser gives a choice of crushed ice or ice cubes, but has stopped dispensing ice cubes and gives crushed ice on both settings.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Jul 01, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
LG Refrigerator GR-642AP need to remove water dispenser
i have the same fridge there are 2 screws down the bottom one is behind a round plastik cap you have to pop out the the top has 3 screws that is it not that hard then it pops off unplug power cable plug and clean to your hearts content. mine wasnt pumping water out the inside hose popped off  easy fix it took me 3 years to get around to fixing it today
Feb 01, 2009 | Refrigerators
I want to remove the water dispenser from my LG Fridge GR-642AP
You must turn the water off, essentially disconnecting the refrigerator,(just to be safe as i am not there to do it for you),then you will be able to take it apart. remember to purge the water lines of air when reconnecting them.
Feb 01, 2009 | Zanussi Z57 / 3 Bottom Freezer...
I also have the same problem. No water but the ice maker works.
Jan 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Nov 18, 2007 | Refrigerators
Refrigerators Logo
291 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
