Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price (less than $200) and install it in the old lamp yourself. really easy.
Lamp bad 260962 approx $360
its a hdlp50w151
where would i find it?
i think its ATC332A
Ok i had wrong info before. model number is M50WH72S. Now i turn it on the light blinks then goes off, does this a couple times then comes on with sound only for a couple of seconds then goes off. I used to hear the whinning/spinning noise now i don't hear anything. please help.
I have same thing on a HD50LPW42 Green light comes on then off Then sound come on.Then after two or three times.The lamp will come on .After warm up its OK. I do not think it is the lamp.Its before the lamp.When lamp gets power it is fine.
mine does the same thing..it blinks and does not turn on anymore.
How and where do you replace the bulb on this set?
I KNOW ITS NOT THE LIGHT BULB SINCE I HAD IT REPLACED...WHAT ELSE COULD IT BE? IT BLINKS 5 TIMES, PAUSES THEN TURNS OFF!!!
me 2
