Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready Television
Problem for Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready...
The power went out and came back on, then the TV's
By aandy_4 on Nov 01, 2009
The power went out and came back on, then the TV's blue lens was out of alignment with the other lenses . I reset the convergence but on the last adjustment with all the crosses the bottom blue crosses would not align.
there is also blue shadow images in the picture
Best Solution
posted on Nov 01, 2009
Very Helpful)
SD Tech
Rank: Guru  Panasonic Televisions & Videos  Expert
Rating: 97%, 888 votes
If you have gone into the customer menu and CONVERGENCE is skewed and will not adjust:
One or both of the two STK-392-110 convergence chips that this set uses are bad.
The chips are about 2 1 /2 inches wide by 1 1/2 inches tall and are black in color. They are mounted on metal heat sinks with fins and are side by side--they will have the Stk-392-110 number printed on them in white letters.
If you locate them take a good look at all the light blue resistors in front of them--most are marked 2.2 ohms---look for any that are white or discolored in the middle---if you find one or more YOU HAVE FOUND YOUR PROBLEM.
BOTH chips and any bad resistors need to be replaced and the set adjusted. If you can do this repair you can save a lot of money as you can buy both chips (a pair) on Ebay for about 12 dollars plus shipping.
I have start to finish instructions for this repair on this type of set. Keep in mind, I am not allowed to post MY email address here for you.
If you cannot do this repair yourself, shop around your area--most shops charge 300-400 for this kind of repair--I do them here for 200-250 and have done hundreds of them.
If they say it has to go to the shop--keep looking as any good tech can do this repair in your home in about 1 hour.
If you have any questions or need advice reply to this posting here OR check out all my many solutions here for more information concerning what I have told you.
I am here to help people.
Regards, SD TECH
Comments:
Nov 01, 2009
- Do you want the instructions? if you can solder--you can fix it yourself
SD TECH
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" SD TECH, THankyou for your quick and informative reply to my problem with my Panasonic PT-56TW53. " - aandy_4
Popular Solutions for Panasonic PT-53TW53 53 in.
Questions and Unsolved Problems for Panasonic PT-53TW53 53 in.
Do you recommend Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready Television?
Answer
Answer
my tv. wont turn on and no sound. But I hear a wierd noise.
Answer
my bottom part of tv to the left side became a little wavy and it's showing double and you can see... (More)
Answer
i have a pt-52LCX16,it shuts off and then back on by itself,what is problem ,green light flashes... (More)
Answer
The TV went off and never come on.The lamp light is not on. No power or anything at all
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic PT-53TW53 53 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
