Question about MSI K7D Master Motherboard
Sudden Reboot with K7D Master MS-6501
I am having some trouble with my K7D Master MS-6501 MSI mobo. I've installed all the latest chipset drivers and updated to the newest version of the BIOS and the problem still occurs, it even reboots when I'm using Microsoft Word and other apps such as Photoshop. Which leads me to believe it may be a video card issue. My video card is a nVidia GeForce FX 5500 256MB. I made sure to that the PCI card is installed in the slot closest to the PSU (IRQ 11). I've been researching this for quite some time now and just can't seem to come to a conclusion. I've heard that sometimes this board has issues with USB 2.0 and Creative sound cards, I had installed a SB 24bit Live! but removed it and enabled the onboard audio.
I also disabled automatic restart and the reboots don't give me a BSoD for further info. It appears to be a hardware issue? Ram possibly?
If anyone has any suggestions I would very much appreciate it.
Thanks,
Brian
  • squideekie Jan 03, 2008
    The ram has been tested in other systems and there doesn't seem to be a problem with them.
    Tested with three other monitors, still the same rebooting occurs, thank you very much for you reply.
    "Clean heatsink and fan or replace(use silicone on cpu) and check the
    mobo is correctly fitted and no shorts are occuring with the fitting
    screws."
    I'll give this a try, its an older computer and it seems like a likely solution, both cpu's are running at about 49C and my system is at 22C.
    Do you have any suggestion on cleaning the fans and the heatsink and re-seating the processor with silicone?
    Thanks in advance...
    Problem Solver:
  • 27 Answers
What condition is the heatsink and fan In??? It seems to me that the cpu is getting slightly hot and is shutting down to prevent any damage..
Is the motherboard newly installed if so check that it is situated correctly in the tower.
The newest version of the bios may cause the problem as well especially if you used a flash bios program.
It has nothing to do with the IRQ and how close it is situated to the cpu...
Monitors are also prone to this problem have you tried the system on another monitor..
Have you been into the bios and changed the settings for the display??
If the board sometimes may have issues with usb 2.0 and creative sound cards then that will not cause this problem..
Clean heatsink and fan or replace(use silicone on cpu) and check the mobo is correctly fitted and no shorts are occuring with the fitting screws.
Run all the virus control programs as well to make sure there is not a nasty worm working it,s way through the system..
Lastly and most probably the answer is to try or change the monitor..
Posted on Jan 03, 2008
  • Anonymous Jan 03, 2008
    Take the heatsink and fan off. The fan will unscrew from the heatsink and then with a soft brush clean both as best as you can and also if you can blow something through the both of them to get rid of as much dust as possible..
    There is a compressed can of Air you can buy from a good comp shop that will do the trick..
    There is no need to remove the cpu from it,s socket,just when replacing the H/s and fan put some silicone also known as Nano compound or heatsink compound ( available from comp shop) on the chip and the replace the H/S..You only need a small amount on the chip...Good Luck
6ya staff
SOURCE:
N1996 pm8m-vh ms-7104ver 3.2 for free software download
Hello download the drivers here:
http://www.msi.com/product/mb/PM8M-V.html#/?div=Driver&os=All
Please select your windows system.
Download all the files, and save them in a folder.
The files needs to be unziped, before you install.
Install the chipset driver first, before installing the other drivers and reboot.
If the mainboard model is wrong, select another here:
http://www.msi.com/service/download/
By entering the ms xxxx number, from the mainboard.
Good luck
Jan 24, 2013 | Computers & Internet
Msi K7 sem finding drivers
Hello seach here at msi:
By entering the ms xxxx number, printed in on the mainboard.
When you find the mainboard, select download and drivers and select your windows system.
Download by click on the zip file, and please unzip the file, before you install.
Start with installing the chipset driver, and reboot.
Good luck
Jan 13, 2013 | Computers & Internet
How to download the drives for my motherboard
Hello download the drivers here at msi:
http://www.msi.com/product/mb/K8MM-V.html#/?div=Driver&os=All
First select your windows system.
Download the driver by click on the zip file.
Unzip the file before you install.
Start with installing the 4 in 1 chipset driver and reboot after the install is done.
And continue with the lan, sound, and vga.
Good luck
Dec 24, 2012 | MSI Ms-7142 K8mm-v Motherboard Via K8m800...
Draiver for msi(ms-6970) compatible for windows7
Hey there, get the latest drivers for the Bluetooth adapter for the ms-6970 MOBO here:
http://www.laptop-software.com/compaq-drivers/msi-btoes-ms-6970-bluetooth-usb-dongle-windows-driver/
Have fun :)
Aug 15, 2011 | MSI ms-6970 Bluetooth Wireless Adapter
I need driver usb 2.0 for my mother board MSI 865PE/G Neo3 MS-6728 (v3.X)
Windows should find and install the latest themselves, try letting it do a driver search online to find the latest.
Otherwise get from the manufacturer. Try here:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=600
The chipset drivers should do it.
Feb 04, 2010 | MSI 865PE Neo3-FS Motherboard
Ms 7142 Msi board, cant install xp with sata hdd
I think this is your board, K8MM-V. The following is the link to all drivers and info regarding said mobo:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Dec 30, 2009 | MSI K8MM-V Motherboard
Not working audio
Download and install the audio driver from the following website:
http://download1.msi.com/files/downloads/dvr_exe/amd_ac97_10b.zip
Hope this helps u buddy..
Aug 09, 2009 | MSI K7D Master Motherboard
Micro star mainboard ms-6163
Hi
MS-6163 Pro Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports up to Ultra DMA 33 operation mode.
MS-6163 Pro - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=340&maincat_no=1
**** Other MS-6163 ****
MS-6163FC Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-6163FC - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=341&maincat_no=1
MS-6163VA - Systemboard IDE controller utilises VIA VT82C596B Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-6163VA - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=342&maincat_no=1
MS-BX Master Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-BX Master - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=319&maincat_no=1
Regards
Mike
Mar 27, 2008 | MSI MS-6163 Pro Motherboard
Open Questions:
Outlook MAil Contact NuMbER {?}{1?.855?.536*?*5666}#[email protected] COLORADO call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
Nov 11, 2019 | Best Computers & Internet
Outlook MAil Toll {1^855^&536^&5666}#[email protected] Free NuMbER HELP DESK call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
See all MSI K7D Master Motherboard Questions
MSI K7D Master Motherboard Logo
117 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
