Question about Kenwood KAC-7202 Car Audio Amplifier
Multipal amps im trying to power two amps at the same time, one is a 4 channel amp and the other a 2 channel amp. i can get the power light to come on the 4 channel but cant get any responce fromth 2 channel amp. also even though the power light is coming on no sound is coming from the speakers.
  • 6 Answers
Make sure your speakers are connected correctly if subs and are inside the box then check connections also at times the rca at the back of the head unit can disconnect. if power light is on then error is either speakers not connected correctly, rca faulty or not connected or speaker output on amp is blown
Posted on Jan 04, 2008
What is the very best way to wire 3 sets of speaks and 2 subs through a 4 ch. amp and a 2 Ch. amp.?Thank you, Paul
Ummmm Im gonna give this a try-If it were me i would run the 4 channel ground pounder on the doors and rear panels -the front 2 channels run the component set exclusively at 2 ohms per channell and run the 8 inch 3 ways in parallel with the rear deck speakers for a combined load of 2 ohms per channel on the rear channells-naturally the 8 inchers and the 6.5's are going to be able to handle a little bit more bottom end than the component set so you can feed a little more midbass to those rear channels- I dont know the resistance of the coils on your subs or the model of the MA amp you are using but if you can throw 600 or 700 on your subs that should be sweet enough- hope its not a waste of your time or maybe you already tried it set up that way-good luck though
May 27, 2009 | Alphasonik (PMA640A) Car Audio Amplifier
I have a kicker zx700.5 amp
Hello aj_vidal22,
Here's the link to MTX's sub page where you can view or download the information you need to properly wire the subs to your amp.
For maximum power, you'll need to wire the subs so that they present a 2 ohm load to the sub outputs on your amp. That will give you the full 420 watts RMS the amp is rated for. Likewise, you,ll want the run the front 4-channels at 2 ohms. Run separately, they produce 85 Watts times 4 channels, or if bridged, 130 watts times 2-channels. But if you run fronts at 4 ohms, they only produce 70 watts times 4 channels and your sub output at 4 ohms drops to 210 watts.
Hope this helps.
Apr 17, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
I have a rockford fosgate p250.2 amp hooked up to two 12' subs but the amp is not powering on... instead the protect light is on and im not sure if its because its so cold outside... please help and thank...
Remove the load from the amplifier (subs) and the RCAs
If the light stays on, there are internal problems with the amplifier, and it needs to be serviced.
If the amplifier works normally, attach the RCA's and power on again.
If it remains on, connect one sub, and then the other.
Your amplifier is a 2 channel amplifier rated at
60 Watt - 4 Ohm - 2 channel(s)
125 Watt - 2 Ohm - 2 channel(s)
250 Watt - 4 Ohm - 1 channel(s)
Your amplifier is not rated for a 2 ohm mono load.
If you have Single voicecoil subs wired in parallel, you have a 2 ohm mono load - your amplifier will eventually fail.
Jan 16, 2009 | Rockford Fosgate Punch P2502 Car Audio...
Help me...
If you had 4 single voice coil speakers you can create either of those 2 ohm or 4 ohm setups. If you run 2 of them in parallel you will get the 4 ohms. If you run 4 of them in parallel you will get the 2 ohms. In parallel I mean that you connect the positives together and run them to the positive on the amp and the connect the negatives together and run them to the negative on the amp. Let me know if you need more help. Good Luck.
-Andrew Hawkins
Jun 24, 2008 | Cadence TXA 6004 4 Channel High Power...
2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
you have a foulty amp i wtake it bk and change it
Dec 27, 2007 | Hifonics Brutus BX 1505D Car Audio...
Sub+amp configuration
With a single 4-ohm subwoofer, usually the best choice is a 2-channel amp that can be bridged to a single channel. In your case, the sub is rated for 1000 watts. Not many amps are rated for that kind of continuous power into a 4-ohm load. Kicker doesn't list a minimum power rating, which isn't unusual in subwoofer specs. Depending on your budget, I'd look for an amp rated for 300-500 watts minimum; the higher, the better, up to 1000 watts. Most amps will have several power ratings, based on the load impedance and number of channels driven. A typical 2-channel amp might be rated like this: 150 watts x 2 channels at 4 ohms 300 watts x 2 channels at 2 ohms 500 watts x 1 channel at 4 ohms. The power rating you'll want to look at will be the 1-channel, 4-ohm rating. You can look at mono amps, too, but in the power ranges you're looking for, a 2-channel amp will probably give you the best value. However, if you can find a mono amp with a high enough 4-ohm power rating, it would run cooler and might last longer than a 2-channel amp with comparable power. When looking at mono amps, you'll find their highest power output will be at 2 ohms or 1 ohm; make sure you're checking the 4-ohm rating when making comparisons. Some amplifiers that might work well for you: Kicker SX900.2 Kicker ZX850.2 Alpine PDX-1.1000 Rockford T600-2 Hifonics ZXi 1006 Premier PRS-D2100T Power Acoustik OV2-2200
Jul 05, 2007 | Kicker C12-4 Car Subwoofer
Kenwood KAC-7202 Car Audio Amplifier Logo
54 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
