Question about Panasonic CQ-Vd7001U
Turn on and off
When i power it on it stays on and i can hear it reading the cd and then it powers off and then on again and repeat. no buttons work when this is happening and the screen doesnt come out.
thanks,
Jerod
Me pueden conseguir la cintilla del estereo
Posted on Jan 03, 2008
I have problem with CD player.
The drive tries to read the CD but fails, then "resets" to try again. It is likely the complete unit will have to be replaced even though the other functions work.
May 04, 2014 | Panasonic Car Audio & Video
Tascam CD-RW700 Not Working
Mine is doing the same thing. By pluging and unplugging the power back and forth sometimes I get it to read the disc and it stays on. If you get yours going then I suggest always leaving it on. It doesn't draw much. A temporary solution until you figure out how to fix it.
Apr 22, 2013 | Tascam Cd-Rw700
The PS3 system reads discs with music and video but does not read discs with games on for PS3
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Thanks!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jan 09, 2011 | Sony Playstation 3 (PS3) Console
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Samsung rear projection tv does not come on
The power supply circuit board has probably gone bad. Repair cost for an in home service call by the major players would be about 450$ plus tax usually with a 90 day guarantee.
Mar 14, 2010 | Samsung HCN4226W 42" Rear Projection...
Blank screen, not reading dsc
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
Can't print
Turn the printer power off.
Press and hold the button on the front and turn the power on, do not release
the button until the power is one. Briefly release the button and press it
again, watch the lights cycle. When the Drum light comes on release the button
immediately. This should print a test page. You may have to repeat this until
you get it right. If that works then the printer is OK.
mostly, if the printer is in good condition, this problem could be resolved by resetting the printer and re-installing the driver and its software.
Jul 24, 2009 | Brother HL 1440 Laser Printer
My ps3 is not reading my games
My ps3 didnt read my ps3 games..followed these instructions and it worked!!
http://boardsus.playstation.com/playstation/board/message?board.id=ps3updates&thread.id=52730
1. Plug in controller
2. Have system in standby mode (red light)
3. Hold down power button for a full cycle (will turn on and back off again)
4. Hold power button again will hear 2 single beeps then a double beep.
5. As soon as you hear the double beep immediately remove your finger from the power button.
6. Hit the PS button on controller when it tells you to
7. Go to ONLY option 3 (restore)
8. WARNING: select any other option and you can wipe out everything ONLY USE OPTION 3
9. Follow on screen prompts
Thanks to Krazyfox
Apr 19, 2009 | Sony PlayStation® 3 (80GB) Console
Panasonic CQ-Vd7001U Logo
46 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
