Security Systems and Surveillance
Problem for Security Systems and Surveillance
Generic problem for all Security Systems and Sur...
How to unlock a cathedral electronic saf...
By info59298 on Nov 01, 2009
Im in a bit of a mare, I have a cathedral electronic safe, model ea25 but cannot find the overide key and as such when I put my combination code in it does not accept it
How do I reset the combination code to get it to open without having the override key?
Best Solution
posted on Nov 12, 2009
Very Helpful)
stonefisher
Rank: Apprentice
Rating: 100%, 5 votes
Well theres three possivilities for why the code does not work:
1. its possible the battery is dead which is why the code is not beingaccepted. As I understand it the battery compartment is on the outside of the safe so install a fresh battery and try again.
2. You may have changed intentinally or accidently the code. Go though all your reguler numbers and see if it unlocks the safe then try similer numbers in case it was imput incorrectly when set.
3. Your safe is broken. tough luck.
If you cant get into the safe with the code you need to take it to someone with powertools (if you didnt have it bolted down) or have someone come to the safe. 10 minates with an angle grinder should make a big enough hole to get the contents out.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Security Systems and
Questions and Unsolved Problems for Security Systems and
Answer
i need wireless security that i can record to my computer (etc) that i use a/c power as main power.... (More)
Answer
How do I change the battery in the Sentry V360? The battery is totally dead and I can't open the... (More)
Answer
I need the factory code for my Sentry Safe Fire-Safe Electronic Personal Safe SB0500. There was no... (More)
Answer
Need a new remote Nutone 580 Scoville garage door opener -- receiver is R597
Answer
when you change battery how do you stop it fr beeping?
Describe your Security Systems and... problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Security Systems... Experts
Top Audio & Video Equipment Repairmen
in Augusta, ME
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
