Question about Protron PLTV-26 26 in. HD-Ready LCD Television
PROTRON 26" LCD TV
Hey, I just opened my 26" Protron TV that I got last year for christmas and hooked my PS3 up to it using the RCA Component Video Jack(Y,Cb,Cr) and I tried setting my PS3 to 1080i but when I do. The screen stays blank.
Is this because the TV doesn't have that resolution or is there a setting I need to toggle before I can get that resolution?
I have had the same issue when i got it...i connected the ps3 and the 360 to each Component ports..and one of them would work...the reason is that one of them only supports like dvd, vcr players..and the other can support the ps3 and the 360..
Posted on May 12, 2008
There should be two seperate component ports, both do different types of signals (i/p). Try the other port and it should work.
Posted on Jan 20, 2008
PROTRON 26 INCH TV SOUND BAR
On some TVs, you have to turn off internal speakers to direct sound to external audio connectors.
Sep 29, 2017 | Protron PLTV-26 26 in. HD-Ready LCD...
Protron PLTV 26
If you provide me with the make and model of the remote, I would be more than happy to get you the codes, thanks
May 13, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
I'm connect my PS3 TO MY PROTRON 26 TELEVISION using a HDMI TO DVI cable.....When changing the source to DVI, the error "INVALID MODE" appears........Does this mean that it is not humanly...
Temporarily hook the Playstation up to another television and change the resolution in the display settings to 1080i and try again. If that does not work, try lowering the resolution again to 720p. If this set has component video input (Red, Green, Blue video cables) try that as well if possible. In fact, this may be the only way to hook this up and have it work in high definition because this set may not be HDCP compliant. You will have to check the owner's manual for its specifications. If all else fails you will have to use the composite (yellow) video cable to hook it up. It won't look pretty, but it should work. Good luck.
May 06, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
Protron PLTV-26 gets power but nothing else. No
i have a protron lcd menu light keeps flashing but tv wont come on any help would be appreciated.
Sep 06, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Proron pltv-4250 no signal
THE BEST INPUT ON YOUR SET IS THE HDMI INPUT.2ND THE COMPOSITE INPUT. 3RD THE COMPONENT INPUT. AND 4TH THE ANTENNA INPUT. MOST DISH BOXES HAVE AT LEAST THE COMPONENT OUTPUT. YELLOW IS THE VIDEO AND RED AND WHITE FOR AUDIO. USE RCA CABLES TO GO FROM BOX TO LCD SET. ON THE DISH BOX YOU CAN GO FROM ANTENNA OUT TO THE CABLE OR ANTENNA IN ON THE LCD. SWITCH TV TO CHANNEL 3. AND TURN YOUR DISH BOX ON.
Nov 22, 2008 | Protron PLTV-4250 42 in. LCD Television
Connecting a Protron PLTV 3250 to a home theater system
Standard RCA cables are fine to connect both units. If home theater and tv has Component Video (Green-Red-Blue) connections, you can get better video result.
Sep 11, 2008 | Protron PLTV-32 Television
Need a replacement lamp for a Protron 26" LCD TV
This is an lcd tv. It does not use a lamp. dlp tvs use lamps. You have fallen into the trap many others have. I am a servicer and I have found there are absolutely no parts, no service manuals, nothing at all available to repair any Protron set. You save some when you buy, but when they break, throw it out.
Feb 03, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
134 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
