Heaters
Problem for Heaters
Generic problem for all Heaters
Reddy heater will not keep running
By chuck62959 on Nov 01, 2009
30,000 reddy propane heater starts and runs as long as I hold the button in. when I release the button it quits
Solution #1
posted on Nov 04, 2009
Not Rated)
tbugger
Rank: Guru
Rating: 90%, 77 votes
Test the thermocouple: Normal 0 Heater will run as long as the control valve is pressed.
According to DESA test these parts. NOTE: Not all heaters are equipped with
A relay.
Thermocouple
Turn off gas supply. Remove thermocouple
from gas valve. Using a digital
multi-meter set to the lowest DC millivolt
setting (meter needs to have alligator clips
on ends of leads), clip black lead to the
very tip of thermocouple (end removed
from valve). Clip red lead to the outer casing
of thermocouple for ground. Relight
unit output should be between 18 and 28
millivolts.
Relay
Turn off gas supply. Remove bottom of
base (if equipped). Relay is a normally
open circuit between terminals 4 and 6
which closes when current is supplied.
Using a digital multi-meter measure the
resistance. With no power to unit, resistance
between terminals 4 and 6 is open
circuit or no resistance. Apply power to
relay. Resistance between terminals 4 and
6 should be less than 100 mili ohms.
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
best heater for a 5,000 square foot monolithic dome
Answer
how can you buy things for less than what they ask for?
Answer
Heater won't stay lit after button release . Burner lites and heat builds but as soon as the valve... (More)
Answer
I have a 75 btu fa multi fuel construction heater. ran great for one tank of fuel now it runs for 5... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
in , NY
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
