Question about HP PhotoSmart 7550 InkJet Printer
Cartridge cradle is stuck
How do you clear the cartridge cradle jam, it is stuck at the right side of the printer?
I've had the error message that the cartridge cradle is stuck to check for paper jams or something in the path of the cartridges. I've also had the cartridges stuck on the left side. With grinding and stuck noises.
I would like to try the solution given, but my problem is 'how do I get the top cover off'? I found two torque screws behind the rear access and took them out, but the cover still won't budge. What am I missing?
I did find a huge pile of ink buildup on the far right side (like an ant hill) and cleaned out as much as I could reach.
  • Anonymous Mar 31, 2014
    the ink cartridge is stuck on the right side and there is no paper or object obstructing
    Sergeant:
    Champion:
  • 347 Answers
Hi KHphoto, you can see this steps to fix your printer jam,
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch cartridge cradle is stuck - c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
original post*
If you are still having problems let me know.
Posted on Jan 03, 2008
  • Santiago Vallejo
    Santiago Vallejo Jan 03, 2008
    Hi again, go Here
    and see the Print cartridge errors section. It will tell you how to fix a cartridge jam... "open the left side..."
    Problem Solver:
  • 72 Answers
Try to see the rubber belt which moves the cartridges if it jumps out to its path way, and using screw driver to return to its path. you can see that when openning the top cover just like changing cartridges..
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
Printer says "Open Door Clear Cartridge Jam" How
You might wanna try removing and reinserting the cartridges and make sure that they are properly fitted in.
Sometimes cleaning the cartridge and the carriage where you took out the cartridges from with a damp lint free cloth does the trick.
If you still have that message, open the cartridge access door.
If the carriage is stuck at the right side of the printer, move the carriage to the left side by hand. If it's stuck on the left side, try moving it by hand in the right side of the printer. Then while the printer is turned on, unplug it from the wall outlet and then plug it back in.
If the printer does not turn on, use the power button.
Try printing again.
Feb 03, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Print cartridge cradle is stuck error message
The cartridges & container must be removed and reinstalled.
Apr 03, 2009 | HP PhotoSmart 7760 InkJet Printer
Error Message - "Print Cartridge Cradle is Stuck. Clear jam."
open the printer - take out the print cartridge and put it back in
Mar 20, 2009 | HP PhotoSmart 7960 InkJet Printer
HP8250 printer
Try this: Remove both ink cartridges. Unplug the printer for a few minutes. Plug it back in and re-install the cartridges.
Jun 26, 2008 | Office Equipment & Supplies
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
Nov 27, 2007 | HP PhotoSmart 7550 InkJet Printer
HP PhotoSmart 7550 InkJet Printer Logo
744 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
