Standard Televisions
Generic problem for all Standard Televisions
Older toshiba tv cx32621
shared by 2 users
posted by rotax on Jan 03, 2008
we were told it needs a vertical hold part - the top 3-4 in of the screen have horizontal lines and roll ? We purchased in 1990 and have bought a new tv and want to give this one away to a friend but may cost too much to fix. Someone said the verticle hold switch or button or whatever is too close to some other button and it over heats - they said this was common.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by big als pals on May 17, 2008
bought in 1992, chassis no.9155. bottom 5'' of screen is black, is it worth
fixing ? What is the part no. and can a layman do it ? If a technican
repairs it, about how much ? Should I put in the garbage ?
Al, e-mail info@afcd.ca
Solution #1
posted on Jan 15, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
CHANGE C308 220UF A35 VOLTS NEAR I.C VERTICAL
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on older toshiba tv cx32621:
I don't want to Accept this solution
Solution #2
posted on Jan 03, 2008
Not Rated (0)
sedonix
Rank:Guru Guru
Rating: 86%, 497 votes
My experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Thank You!
Can you Help with these Standard Televisions problems?
Okay so this girl i know has this TV and the power cable...
Sansui DTV2760 27" TV
i left my tv on and when i came back from running errands...
RCA F32648 32" TV
My sister has this 2001 TV and she says it has a mind of...
Sanyo DS31520 31" TV
i need the code number to program it in
Loading problems.
Repair Service
Find Standard TV Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
