I have a wireless micro innovations keyboard that seems to be locked. Any idea how to unlock it? I wiped it down today and has not worked since. I've changed the batteries; shut down my computer; disconnected the keyboard and tried ctrl-alt-F12.. nothing worked.
This could be bad or just annoying depending on how you wiped it down.
There should be a monitoring utility that will let you choose settings and see what the keyboard batteries are. You should be able to see if it is finding the keyboard. This should also be where you can unlock the keyboard or use a security code.
There should also be a reset button or connect button along the bottom of the keyboard as well as one on the antenna. Press the antenna first then the keyboard button. The lights on the antenna should flash. As well when you press caps lock or numlock a light should change on the antenna.
One thing to check is that the antenna connector is plugged in. On mine it comes loose just by walking by it. Just needs a push to make sure its inserted and hasn't come loose.
If none of those get your keyboard back then it may be that you damaged the keyboard.I would try leaving it near a heating grate so that the warm air blows over it for a day or so. It may be enough to dry out the inside enough to work. Past that the keyboard may be repairable but you would have to find someone to fix it and you would need to check that cost against replacement.
any way to program button #2 to ? (model kb 1045 lsr) Could do this on my old Micro Innov 5 button...
(More)
any way to program button #2 to ? (model kb 1045 lsr) Could do this on my old Micro Innov 5 button mouse
Hi, i own a Micro Innovations KB1045LSR wireless keyboard & laser mouse and i lost the...
(More)
Hi, i own a Micro Innovations KB1045LSR wireless keyboard & laser mouse and i lost the software disc. i am running vista and need just the software. i tried going on their support site 'www.microinv.com' but ended up getting a redirect to Digital Innovations. Where can i find the software for free w/o registration/signup?
hello i am having problems with both my keyboard and mouse. well my keyboard.... it switches the...
(More)
hello i am having problems with both my keyboard and mouse. well my keyboard.... it switches the keys on me if i press the (.) or any other symbols it wont put the right symbol i press. as for my mouse... if i click on one thing it highlights everything and wont click on what i want it to click on. and my job is to be on the computer and i cant wrk with this messing everything up like it is
