Question about Jabra BT250 Consumer Headset
Connection but no sound
I have a bt250v that was working previously however now i have no sound in the headseat. when i hit the buttons they work and i can say a voice comand however i can not hear anything in the ear piece. this headseat is only 1 week old.
  • 1 more comment
  • Anonymous Feb 17, 2008
    No tones in earpiece at switch on and switch off no audio at any time basically. Earpiece previously worked just suddenly stopped working. tried resetting and re pairing etc no change.
  • nohearit Feb 22, 2008
    Same problem. Jabra connects with phone, but no sound from headset. Have tried adjusting volume, no luck.
  • dapperdunn May 07, 2008
    My Jabra worked perfectly before. I havent used it for a few months. Now i would like to use it again. I can connect it with my phone, but cant hear anything through my earpiece. I,ve tried dissconnecting and reconnecting, but with no luck. Can anybody help please??
I've got the same problem. I already tried to delete and repair the two devices and it's still not working.
Posted on Apr 22, 2008
I had same issue,
what i did was delete the device from bluetooth device list on phone and added it again with passcode 0000
now it works again.
Posted on Apr 07, 2008
  • bernadett597
    bernadett597 Aug 26, 2012
    i also cant hear anything switched on anf off delete the device in the bluethooth list enter passkey/pin on the phone but it really cant
Left channel no sound on logitech headset
Usually something like this is simply the wire at the headseat becoming broken by twisting and stress. If you gently twist and push right where the wire enters the ear cup. It will work and then stop as the wire make a connection. Unless you can solder you will end up replacing the set. Make sure to try it out on a different pc or mp3 player etc just to make sure it is the headset.
Sep 10, 2012 | Logitech Audio Players & Recorders
I can t connect to my headseat bluetooth
If all the pairing instructions are being followed and the connection still can't be made Its usually compatibility issues that's the problem.
As this is a Bluetooth version 1.2 device if you are attempting to pair it with a newer 2.x compatible device it may not work properly even though backward compatibility is supposed to be a given.
In that case the best answer is to purchase a newer Bluetooth 2.x compatible headset to work with your Bluetooth 2.x enabled device.
Feb 04, 2010 | LG SGBS0001606 Bluetooth HBS-200 Stereo...
Hello at the frist time that i work with my loptob i can hear sound frome the speaker but when i reinestall win xp i can not hear sound from the speaker bou i can hear it from headseat
Hi there, it could be a couple of different things. First off, try reinstalling the driver to be sure. If still no success, double-click on Volume Control in the System Tray, once you're in there, Click Options > Advanced Controls, it'll now expand with the Advanced button, click the Advanced button and make sure PC Spk Mute is not checked, as it will disable the internal speakers but not the headphones.
Jan 19, 2009 | Dell Inspiron 1501 Notebook
I want help to fix my headset whith microthone.
You better use analog multitester so you can hear a static sound coming from the headseat when you going to test.If happen you can't hear a static sound the common problem is the wire is breaks or cuts,then find where the cuts is and join it so it's works again.
Hope it may helps you;
Nov 28, 2008 | Audio Players & Recorders
JABRA BT250V Hearing Problem
Cannot get my Jabra BT 250v to work with my Blackberry Curve 8310. Phone indicates I am paired, but there is no audio through earpiece. You can still hear audio through phone. Help.
Jun 18, 2008 | Jabra BT250 Consumer Headset
BT250v vibrating after picking up the call
Check Jabra website for manual.
It is a simple hold volumne button up or down when switching on or off to disable /enable it
Apr 21, 2008 | Jabra BT250 Consumer Headset
Wreless heads set that comes with WarHawk game
the wireless headseats are hard to connect to the game to the point of why get a wireless headseat. you have to reconnect it every time you wanna play but ne way...after configuring the ps3 (in the settings menu under accessory settings and register bluetooth device) then you have to connect it throught the menus in Warhawk to set up bluetooth then while in waiting area press connect button on headseat. otherwise get wired headseat plug in and go
Jan 04, 2008 | Sony Playstation 3 (PS3) Console
No sound
Had the same problem with the BT250v 'connected' to my Nokia 6021. When connected to my notebook, the 250 did produce sound, so decided the Nokia was the problem. Fixed the problem by doing a full reboot of the phone like this:
Jabra: Turn off the 250
Phone: Delete the BT connection to the Jabra (in BT settings)
Phone: Switch off BT
Phone: Turned off the phone (I've even removed the battery)
Phone: Turned on the phone
Phone: Switch on BT
Jabra: Turn on the 250 for detection
Phone: Look for audio devices
Phone: Connect to Jabra
Problem fixed!
Sep 02, 2007 | Jabra BT250 Consumer Headset
Jabra BT250 Consumer Headset Logo
171 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
