Home | Reddy | Heater-30-55,000 BTU Variable | ON THE BACK OF MY RED...
Reddy Heater-30-55,000 BTU Variable
Problem for Reddy Heater-30-55,000 BTU Variable
ON THE BACK OF MY REDDY HEATER (KEROSENE) THEIR
By oscarwoodlaw on Nov 01, 2009
ON THE BACK OF MY REDDY HEATER (KEROSENE) THEIR ARE 2 HOLES THAT 2 LITTLE BLACK FITTINGS GO IN. 1 OF WITCH STIKS OUT FURTHER THAN THE OTHER. OK IS 1 OF THEM SUPPOSED TO BE COMPLETELY CLOSED OFF. IF SO WITCH 1 AND DTHE OTHER IS IT SUPPOSED TO HAVE A FITTING WITH A HOLE IN IT AND SUM KIND OF SPRING THAT GOES IN IT. MY HEATER WILL START TO RUN THE FAN WILL *** ON AND IT LOOKS RED IN THEIR BUT ITS NO FUEL GETTING TO IT AND ITS SOMETHING TO DO WITH THOSE TWO WHOLES IN THE BAK OF IT
Solution #1
posted on Nov 04, 2009
Not Rated)
tbugger
Rank: Guru
Rating: 90%, 68 votes
Instructions for setting the pump pressure.
http://www.reddyparts.com/pressure.htm
Was this helpful?
Yes
No
Solution #2
posted on Nov 01, 2009
Not Rated)
roniecon
Rank: Guru
Rating: 88%, 637 votes
Yes these are where you adjust the fuel pressure on the pump.
Was this helpful?
Yes
No
Popular Solutions for Reddy Heater-30-55,000 BTU
Questions and Unsolved Problems for Reddy Heater-30-55,000 BTU
Do you recommend Reddy Heater-30-55,000 BTU Variable?
Answer
Answer
The heater starts fine, but the gas flow is significantly reduced after a few seconds. Tried a... (More)
Answer
Tries to fire but shuts down after a few seconds. I have already ran it a few times this week. Now... (More)
Answer
Turns on with flame and fan and after 5-10 seconds shuts off. When I plug it in again, the same... (More)
Answer
my heater will fire up and run then if i unplug it and plug it back in the motor spins slow and the... (More)
Answer
55000 btu kerosene heater I ran great until i moved the heater to another room, plugged it back in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Reddy Heater-30-55,000 BTU...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
