Question about Xerox DocuPrint N4525DX Printer
Tray not lift
The tray motor does not appear to be receiving message to lift. I have tried both the tray 1 and tray2 motors, switching the postions without success. Where could the problem be? The LED message onoy says 'Tray 1 problem...turn off/on.
    President:
  • 2,072 Answers
Most likely you have a bad MCU board.
Posted on Feb 19, 2008
Konica minolta buzhub c360 giving error c1183
Elevate drive malfunction
<When FS-527 is installed> • During downward movement, the tray 2 upper limit sensor (PS24) is turned OFF and the tray 2 lower limit sensor (PS21) is turned ON. • The elevate motor (M15) lock signal remains set to H for a set period of time while the elevate motor (M15) is turning. • The tray2 upper position switch (SW2) is turned ON even after the set period of time has elapsed while the elevate motor (M15) is energized. • The tray2 lower position switch (SW3) is turned ON even after the set period of time has elapsed while the elevate motor (M15) is energized. <When FS-529 is installed> • When the exit tray is moving up: When the tray up/down motor (M2) starts rotating with the output of the tray lower limit sensor (PS6) being ON, PS6 is not turned OFF even after the set period of time has elapsed. • The paper surface detect sensor/1 (PS2) or the paper surface detect sensor/2 (PS3) is not turned ON even after the set period of time has elapsed after the tray up/down motor (M2) starts rotating. • When the exit tray is moving down: The tray lower limit sensor (PS6) is not turned ON even after the set period of time has elapsed after the tray up/down motor (M2) starts rotating. Remedy When FS-527 is installed: 1 Check the connector between M15-FSCB PJ4 for proper connection and correct as necessary. 2 Check the connector between PS21-FSCB PJ21 for proper connection and correct as necessary. 3 Check the connector between PS24-FSCB PJ16 for proper connection and correct as necessary. 4 Check the connector between SW2-FSCB PJ3 for proper connection and correct as necessary. 5 Check the connector between SW3-FSCB PJ3 for proper connection and correct as necessary. 6 Check the connector of M15 for proper drive coupling, and correct as necessary. 7 PS21 I/O check, sensor check. 8 PS24 I/O check, sensor check. 9 SW2 I/O check, sensor check. 10 SW3 I/O check, sensor check. 11 M15 operation check. 12 Change M15. 13 Change FSCB.
When FS-529 is installed: 1 Check the connector between M2-FSCB CN12 for proper connection and correct as necessary. 2 Check the connector between PS6-FSCB CN5 for proper connection and correct as necessary. 3 Check the connector between PS2-FSCB CN4 for proper connection and correct as necessary. 4 Check the connector between PS3-FSCB CN4 for proper connection and correct as necessary. 5 Check the connector of M2 for proper drive coupling, and correct as necessary. 6 PS6 I/O check, sensor check. 7 PS2 I/O check, sensor check. 8 PS3 I/O check, sensor check. 9 M2 operation check. 10 Change M2. 11 Change FSCB.
Apr 12, 2016 | Konica Minolta Office Equipment & Supplies
Konica Minolta Magicolor 4690MF I have a caution error tray2 open close tray2 can someone help close tray2
Check the sensor for tray #2. Another remove the tray #2 check for broken acturator and or broken tabs that go into the machine to indicate the printer draw two is closed. Lift the printer off tray two use just one and bypass does that work eliminates the circuit board of the machine.
Nov 30, 2015 | Konica Minolta Magicolor 4690MF...
I have (caution) tray2 open close tray2 can you help to close tray2
sir Check the sensor for tray #2. Another remove the tray #2 check for broken acturator and or broken tabs that go into the machine to indicate the printer draw two is closed. Lift the printer off tray two use just one and bypass does that work eliminates the circuit board of the machine.
Tray lifting error hp printer hp laserjet m5035mfp
The tray lifting error is displayed as 60.02 Tray 2 lifting error. To fix this error, check the surface sensor of the paper tray2 in the Manual Sensor Test 2 menu under the Troubleshooting menu.
Connect back the cassette lifter motor and the DC controller PCA's connectors and now, replace the filter driver unit in your printer.
123 hp com Quick HP Printers Setup Easy Installation Guidelines
Dec 16, 2011 | HP LaserJet M4345 MultiFunction Printer
Hp laserjet 4250dtn tray 2 & 3 will not lift
Any message appearing? like 60.X ? '*Open 'tray two' check 'open message (if No check switch 102) YES '*remove tray2 lift drive mechanism(RM1-1074-000CN) check is it working? YES '* check tray mechanism is it engaging to the lift mechanism? '* check connector/cable of lift drive motor* if not working replace lift drive mechanism '* mechanism is good replace DC controller.
RM-1074-000cn
Sep 06, 2011 | HP 4250dtn Monochrome LaserJet Printer
My pansonic 1820p digital copier dislays error code E02-01. The main motor & Tray 1 lifting motor do not run, from kingsley I. O.
The following might work:
Switch off at mains, remove paper from tray 1, close tray 1, switch on, replace paper when prompted.
Hope this helps.
Jan 13, 2010 | Panasonic Workio DP-1820P Laser Printer
Sharp AR-M550 with a paper tray error F3-12
When I first arrive to any service call the first thing I look for is the service log.
Locate the service log on the rear,side or inside the front cover.
Check the last error code and corrective action.
F3-12, Paper does not lift in the tray
Identify how many lift tray is inside your machine.
Check each sensor(s) for smooth operation.
LOOK inside for crack plastic on the lift tray.
Sensor can be defective (non-operational) and no cutting off power to the motor and damage the motor,metal frame and plastic tray.
Use a small METRO VACUUM with a clean bag,
Vac the interior of the unit,
Look for fragment of plastic tray or sensor arm inside the vacuum bag.
Pass the information to a Sharp authorize shop.
Dec 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
IBM Infoprint 1532 Tray Selection
For tray linking to work, both Paper Size AND Paper type must be configured the same for both trays. You probably have the paper sizes the same but types could be different. The is no setting to make tray linking work.. it will do it automatically if the above settings are correct.
Feb 24, 2009 | IBM Infoprint 1532 Laser Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
Xerox DocuPrint N4525DX Printer Logo
73 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
