When you mean does not work, does the unit power up or is it plain dead? If it does not turn on, then you will need to troubleshoot or send out for repair.
If it turns on, but does not provide you with maps, you need to load maps for Australia as you currently have US maps loaded on the device.
Google search for Australia maps for your unit, or contact Garmin customer service.
If you purchased the onetime or Lifetime map update just run Garmin Express, otherwise you may need to purchase those or plan on replacing the Garmin Device. If something happened to the original maps that were on there and you are too cheap to buy new ones, there is no way to load back on those old map files
Unfortunately Nextar does not offer an update for your unit. See units with available updates below.
Map Upgrades for GPS: The below units are upgradable with theNavi Extra maps.
Q4: From Serial #ML0909020001 onwards. From Serial #YF0909123953 onwards
Q4-06: From Serial # ML0909000001 onwards
ME: All serial numbers
43LT: All serial numbers
V4: All serial numbers
V5: All serial numbers
I4-BC: From Serial# ML1004000001-ML1004000504 and ML1005001701-ML1005002700
Important Map Upgrade Information: Please note that refurbished units that have serial numbers starting with MLR or ML999 are not compatible with map upgrades. Navi Extra Mapping Please note that Nextar is unable to answer map support questions once the Navi Extra mapping has been purchased. For any map related questions and/or refunds, please feel free to contact Navi Extra at:https://nextar.naviextras.com/shop/portal/support?selectedTab=contactus.
Press TOOLS (the spanner symbol) Press SETTINGS (the spanner symbol) or LOCALE on some models Press MAPS
There will be a tick beside whatever maps are selected. If the Australian map is not selected press the map name and it will be selected.
When you go to Australia the satellites should automatically pick up your location and load the correct map. If not or if you want to save an Australian location in favoutites before you go; Press WHERE TO When the screen comes up to enter the address you'll see NZ as the country selected At the bottom of the screen you'll see an item CHANGE COUNTRY Press this and you can select Australia This should bring up the map of Australia and you can enter addresses there.
Your GPS will require a map set for Australia to display your location on the screen. You have several medium choices for street level map of Australia.. you can purchase your choice of an instant download, purchase CD ROM or an SD memory card version to install / load on your GPS. The link above will help you choose which works best for you.
uninstall/delete the map pack.......
Then Re-Download the Map Pack.......
Update your Navy Seals game to the newest version update via psn.
Then Reinstall the Map Pack.
That Should Cure all your ills.
Please remember to Rate me
& Testimonial If You Would!.......Thank You!
well you need to update the firmware of your gps also call garmin customer support they are great tell them about the map, also the poor satelite cover might be because of your location or weather conditions
She can purchase the City Navigator Australia DVD and load the Australian maps onto an SD card. Insert this into the unit and she'll then have both S Africa and Australia maps.
