Question about Microwave Ovens
Microwave keeps blowing fuse
When I start the microwave, it starts to make a buzzing sound then blows internal 20 amp fuse within seconds. What could be the possible problem and is it worth repairing?
Thanks in advance
the microwave made a buzzing noise and went totally dead. I replaced the internal 20amp ceramic fuse and set it for 1 second and it buzzed and blew the new fuse.
  • 2 more comments
  • Roofing Tech Jan 17, 2008
    I ran the suggested test on the high-voltage capacitor and all test pointed towards it being bad. I ordered a one, installed same and it works like a champ. Thanks so much for your help!
  • Anonymous Mar 13, 2014
    replaced the internal line fuse after all power was absent from unit.once replaced the unit appeared normal with all lights functioning.immediately after pushing start fuse blew again.
  • Anonymous Mar 14, 2014
    replaced fuse in microwave and it blew so I put another in and it also blew
  • Anonymous Mar 26, 2014
    Can anyone give me an idea what could be the cause of the electrical cut-off, and why? What would need to be repaired or replaced in this case?
  • Microwave Ovens Master
  • 9,098 Answers
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links with info on part testing:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by
entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
GE microwave Model JVM1540DP1CC S/N HT931338B MFG. 5/2010. Fan comes on when door is opened. Also 20 amp internal fuse and the breaker blows if the door is opened while the microwave is cooking.
I don't have the Schematic but did you replace the fuse once? You may need a Slow Blow Fuse. They are marked and just look different
A slow blow fuse is different from a fast acting fuse in its capability to withstand transient pulse currents, i.e., it can withstand the surge current upon power-on/off, thus ensuring the equipment works normally. Therefore, slow blow fuses are often called time-delay fuses.
Hope I helped If I did please "Like"
Mike
Aug 05, 2018 | GE Microwave Ovens
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
Why does fuse keeps blowing within mircrowave
Hello friend, thanks for your post!
Based off the information you have provided I understand that your fuse blows every time your Electrolux microwave starts up. It sounds like it could be an issue within the control panel, capacitor, or circuit breaker. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your microwave to determine the root cause to reduce the risk of unnecessary parts-Matt
Aug 13, 2014 | Electrolux Microwave Ovens
GE Spacemaker microwave makes groaning sound when start button is pressed for a second or two then blows the internal fuse. After replacing the fuse everything seemed to work, lights, exhaust fan, cl
Could be a lot of things but most probably a shorted high voltage diode assembly. If not that then the magaetron or capactors. Remember be careful there are high voltages even when the oven is unpluged. The capactors are usually charged and must be discharged. If you don't know what yor doing then time to get a qualfied tech.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Blowing 25 amp fuses
In that case the outlet your using is pushing out too much electricity. Try calling your local electric company for help or a professional electric repair man.
May 21, 2009 | Emerson Black Microwave Oven
Buzzes when starting then blows the fuse
there is an electrical problem.
my suggestion is that you will have to dispose that microwave and get a new one.
you dont want to chance a fire. andwave c yes mircroan cause fires.
Apr 26, 2009 | Microwave Ovens
Emerson Mwg9111sl microwave blows 20 amp internal fuse instantly everytime.
check your thermal fuse its about 2 inches long white on the outside black on the inside it has 2 wires going to it check for
cotinuity becareful of the capacitor you need to disapate that first by touching the two teminals together with a screw driver
Apr 01, 2008 | LG LTM9000 Microwave Oven
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
If it blows the fuse as soon as it's plugged in, you probably have a shorted door switch, a shorted varistor, or an internally exposed wire shorting to the chassis, etc.
Nov 19, 2007 | Microwave Ovens
Fuses keep blowing out
In case it's still helpful, I'll inject a little sanity into the replies.
If the fuse blows as soon as you hit Start, it's probably a shorted high-voltage capacitor. That's usually economical to repair.
If the fuse blows a few seconds after you hit Start, it's probably a shorting high-voltage transformer. That's usually not economical to repair.
It's not radiation (non-ionizing RF by the way) that's the hazard, it's the voltages.
Apr 08, 2007 | Sharp R-1405 / R-140 Microwave Oven
Microwave not works
WARNING: Microwave ovens are the most dangerous consumer appliance to service due to up to 5,000 V at high current inside. Even with the power off, there is a HV capacitor that can produce a lethal kick. This capacitor must be discharged before touching anything in the microwave generator circuitry. DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. About the only "easy" fix would be a blown fuse, if it keeps blowing, don't go any further unless you know what you are doing. Your likely options are a blown high voltage cap, diode, or the magnetron. Good luck(but luck has nothing to do with it ;] )
Apr 01, 2006 | Sharp R-320H Microwave Oven
Microwave Ovens Logo
506 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
