Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Printer window's vista program trying to get printer working. installed program fine and when went to test print page it comes up with an error. would like help? printer is not that old and was working great but not now.
  • Lexmark Master
  • 1,879 Answers
Have u tried downloading the printer´s driver from lexmark´s website ?
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:463:0:0
Posted on Jan 03, 2008
My Dell Inspiron 1545 has stopped printing
first check the printer cable
then try to uninstall the printer driver
restart the laptop
try to install the driver again
print the test page
Feb 06, 2013 | Dell Inspiron Computers & Internet
NEW HP Photosmart C6280 All-in-One on Vista - Error Printing
Whats the error message and can you try the printer directly connected into your computer?
Also check what your computer says in the printer status -> start -> printers and faxes -> your printer.
Jul 05, 2008 | HP Photosmart C6280 Printer
HP 990cx1 unable to print from Vista
The problem is definitely due to compatibility...To solve this and you want to use vista as well you will need to use dual-booting(two operating systems on the same machine)A wise choice would be a combination of XP and VIsta...This will solve the problem at least until your printer drivers for VIsta are out..
Oct 14, 2007 | Office Equipment & Supplies
Need Dell All-in-One printer 924 to work with Inspiron 530S.
If it doesn't say it is specifically for VISTA then it is not for VISTA.. Even if it does show up on the computer ,that just shows that some driver for that model printer is installed. Not necessary one that will work. Go to the weblink that I gave you. Download the VISTA drive and update the driver, using the one you downloaded ,and that will most lkely fix the problem.
Mar 03, 2009 | Dell 924 All-in-One InkJet Printer
Job Status Window Interface has stopped working.
The issue usually occurs if you are using windows xp drivers on a vista machine. It's strange that the error does not come up when printing from internet explorer 7.0.
There is a file on support.dell.com that you can run to remove any xp drivers and then run the vista installation file. that should take care of these error messages from the operating system.
you can copy and paste the following links to download and run the files :
Patch file to remove xp drivers:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=224499
Driver for vista
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=203951
Feb 17, 2009 | Dell A960 All-In-One InkJet Printer
Hp psc 1210 not working in vista - but diagnostic utility shows all ok - and prints test page
Here is the full-write up on the HP PSC1210. Read through this thoroughly to ensure that you follow all the steps to make it work in Vista, since there is no Vista native driver.
Hope this helps - remember to rate :)
Oct 02, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printer prints multiple pages with DPR1260 print server
I was having the same problem when I added a Windows Vista PC to my home network. My older XP systems workd fine, but the Vista system would keep printing. The following fix worked forme in vista, may work in XP also.
1. First, be sure you have the latest firmware in your DPR1260. Version 1.24 is what I am using.
2. From the printer window (or via controlm panel) select your printer, then select Properties (either right click, or from the menu via File-Properties)
3. In the Properties Window, select the Ports tab. You should see your printer highlighted and checked, under the port heading next to thcheck box you'll see IP_192.168.x.x, under descriptio Standard TCP/IP Port, and undr Printer, the name of your printer.
4. Click the "Configure Port" button, be sure "LPR" is selected, not "RAW". Under LPR Settings, check that the "Queue Name" matches that in our DPR1260 status screen, and be sure SNMP Status Enabled is not checked.
The problem on my Vista machine went away when I changed from "RAW" to "LPR" settings.
Hope this helps.
Jul 28, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Issues Printing with DPR-1260
This worked for me and I was having the same issues as everyone.
http://support.dlink.com/faq/view.asp?prod_id=2705&question=DPR%2D1260+vista
Before I put this solution in (manually adding the printer step-by-step), I could print a test page just fine, but not anything from Office.
Make sure to follow each step in order. I printed off the test page and held it up to the old one and the only thing I saw different was a field named "Shared". It was blank but who knows. I'm just happy the darn thing is working!
Dec 15, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
