Question about Mitsubishi VS-60703 60" Rear Projection Television
Picture in a picture
How to I enable split screen or picture in a picture on lcd tv
pip wont turn off
  • 87 Answers
Do you have original remote?
Posted on Jan 03, 2008
Split screen
either you have the PIP engaged (two different pictures) or if same picture twice a digital issue in the set.
Look for PIP and turn it off or if a swap button see if it swaps the pictures--will tell you if PIP is issue or not.
Jun 07, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How do you split the screen to watch two different shows at once?
to watch two defferent channel in one screen,u just need to activate the PIP feature of you tv..PIP means picture in picture.
May 20, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
How to turn off the picture in picture with no remote? I turned it on one day and magically it was there at the bottome right corner of my screen...
Press Menu on the TV, use the channel buttons to choose Screen, vol+ selects. Then go to View and set it to OFF. (PIP, Split and Off are the choices).
I hope this helps.
May 19, 2010 | Olevia LT32HVE 32 in. LCD Television
How too make work the small pip on a 52" LCD HD tv samsung
All pip or pop features must have 2 seperate and distinct video sources. With your tv you can choose to have cable split with a 2-way splitter and one feed to cable box and the other directly to a second ant connection on back of tv. If you only have 1 rf input on tv then your second source would have to be from a vcr or dvd etc. once you have 2 seperate sources going you select pip and choose what source you want and both main screen and pip screen will appear. obviously you will only have audio on main screen so if you want to hear pip you have to switch back and forth.
Dec 31, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Black square on screen that covers half the picture appeared on my 42" sharp aquos tv.
sounds like you might have PIP turned one (picture in picture) .. if there is no input hooked up for the PIP . you will just get a black screen ... you should be able to move that PIP around and change its size .. indeed turn it off .. look for a menu item called PIP .. select PIP off ..
Nov 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The tv screne picture on my insignia tv is off centered and is split in two
I suppose your TV has a PIP function.
  • check if u have a PIP function on your remote control or
  • Go to the Menu n in the display see if u can see the PIP function or the Aspect Ratio function like 4:3 or 16:9.
  • You have to switch it to standard or normal view to change to one full picture.
Jun 04, 2009 | Insignia NS-LCD19 19 in. LCD TV
Pip screen and tv screen wont produce a picture at the same time
Order a new TV....thats what I have to do. I have the Protron 42", and I cant get any sound, and I cant get the remote to work. Figures, too.....the TV JUST passed its warranty period by 4 days! I havent seen any positive things said about this company, either.
Nov 04, 2007 | Protron PLTV-32 Television
Can't get second picture in Picture-in-Picture (PiP)
Watching two separate tv channels at the same time requires two tv channel sources,i.e. a split of some kind. For instance,the cable coming in thru the wall is split-half to tv or vcr/dvd combo and then to tv,the other half to cable box,then out to tv.If what I described fails,then you may have an actual tv failure.PIP video is generally a separate circuit from standard video.An expert tech w/service literature should be able to help. Let me know if you need more assistance.
Sep 16, 2007 | RCA HD52W56 52" Rear Projection HDTV
Zenith TV E44W46LCD Picture Problem
The PIP module is bad or the video processor circuit. Most likely a main board replacement will be neccasary. Good Luck
Mar 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Televison & Video Logo
129 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
