Question about Mitsubishi VS-55705 55" Rear Projection Television
Mitsubishi vs-45va2 i turn it on and all i get is blue screen with a distorted picture in the back ground. sound is perfect. please help ikeaguirre14@yahoo.com
ITS JUST BLUE AND YOU CAN BARELY SEE A PIC THAT IS WAVEY LIKE IF THERE IS NO ANTENNA.
Posted on Jan 07, 2008
  • Mitsubishi Master
  • 8,617 Answers
Can you be more specific? What kind of distortion are you talking about?
Posted on Jan 03, 2008
I have sound but no picture on my mitsubishi VS-45VA2, what can I do to solve this problem?
Well, today may be your lucky day. This is a 200.00 repair at least, but I'll attempt to help you for free. Most commonly on this set the pip module fails. This is a small standup board mounted on the signal pcb. There are 2 plugs that connect it to the signal board. These plugs are VS and VA. First, Disconnect the power to the tv and remove either the front or rear cover. Use good lighting. Disconnect small standup board from signal pcb using a small screwdriver to undo the two clips at VA and VS connectors. Pins of the VA connector are marked on the board so you can tell which one is pin 1 through 11. Simply jump a small wire from pin 5 to pin 11 and a small wire from pin 7 to pin 9. Make sure the wires do not touch and this will bypass the pip module for testing. With pip module removed and 2 jumpers installed plug set in and turn on. The set should now show a picture but the pip will no longer work. Hope this helps. Good luck, Russmann.
Jun 10, 2010 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-55609 distorted Picture Flickers
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
S.O.S anyone out there
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • No Audio/Video - makes a chirping sound.
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Sep 03, 2008 | Mitsubishi VS-55705 55" Rear Projection...
MITSUBISHI VS-50801 50" TV
Bad convergence IC possible - It's cheap if you do it your self, expensive if you take it to a repair shop. My Toshiba finally came on and stayed on after the IC's burned completely up and smoke poured out the back. Then mine stayed on with a distorted image. A good place for parts -> http://www.electronix.com/catalog/default.php/cPath/6
Apr 29, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Sound but no picture on a Mitsubishi VS-45VA2.
This is the VZ1 Chassis.. CHECK FOR 1200 VDC AT PIN 1 OF CONNECTOR "DK". IF LOW OR MISSING CHECK R5D9 100 OHM 1/2 OFF PIN 1 OF THE FLYBACK ON THE MAIN PCB. 2. CHECK IC401 PIN 8 FOR 28 VDC IF MISSING CHECK R510 1.2 OHM 1/2 W OFF PIN 5 OF THE FLYBACK. IF OPEN IC401 PART # 272P239 If those voltages check out let me know and we will go to the next level. Two other questions do you have video through the pip with the alternate input? and do you have on screen display when you push menu on the remote?
Feb 16, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Open Questions:
Mitsubishi VS-55705 55" Rear Projection Television Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
