Question about Aiwa NSX-AJ20 CD Shelf System
Cannot turn off the Timer
Had never used the timer function. Grand daughter somehow enabled it. I downloaded the manaul and found out how to set/change it. I changed it from 12:30 am start time with a duration of 2 hours... to coming on at a more uninterrupting time and changed the duration to 5 minutes, would love to change the duration to 0 minutes... any help appreciated
    New Friend:
  • 3 Answers
J_warenzek how did you reset the timer?
Posted on Mar 23, 2015
    Scholar:
  • 64 Answers
Can you set the start/stop time to read 00:00? If so try that, it shouldn't go off at all. Another possible solution could be to turn it off and unplug it directly from the wall.... leave it for a minute or so, plug it back in and leave the timmer alone all together. If it has an internal memory, leaving it unplugged for a few minutes might reset the system. There might also be a main reset button hidden somewhere but you will have to look that up in the manual.
Posted on Jan 03, 2008
  • 49 Answers
To deactivate the timer:
Press the TIMER button on the unit until the little clock disappears from the top of the display (the clock is very small located dead center above the numbers on the display screen). Ref. page 17 of the manual.
Hope this helps.
Jeremy
Posted on Jan 21, 2010
Set clock and be able to tell am from pm setting
The Clock uses a 12-hour cycle with a.m. and p.m.
1. Check that the oven is off.
2. Press CLOCK.
3. Press TEMP/TIME "+" or "-" arrow pads to set the time of day, including a.m. or p.m.
4. Press CLOCK or START
The Timer can be set in hours or minutes up to 12 hours and 59 minutes.
1. Press TIMER.
2. Press TEMP/TIME "+" or "-" arrow pads to set the length of time.
3. Press START to begin the countdown. If enabled, end-of-cycle tones will sound at end of countdown.
4. Press TIMER twice to cancel the Timer. Do not press the CANCEL/OFF keypad because the oven will turn off.
5. If the TIMER is running, but not in the display, press TIMER to display the countdown for 5 seconds
Delay Start:
The Start Time keypad is used to enter the starting time for an oven function with a delayed start.
Hope this answers all you questions about your stove.
Jaye
Nov 04, 2013 | Whirlpool RF263LXTQ Range
How do you set the times on a Westek TE02 Timer
Thanks for describing timer buttons. And including brand and model number.
I think there are two models, one is 24-hour and other is 7-day.
Copy following link to identify timer, and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Westek
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 03, 2012 | Hardware & Accessories
Ringgrip timer manual
Raindrip water timer?
Copy following link to identify many different water timer brands and product manuals for each.
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
If you do not have water timer, then add a comment and carefully describe the timer in detail.
Aug 31, 2012 | Hardware & Accessories
RDR-HDC200 Stuck on DVD mode showing above little red circle(clock?) bottom left. Cannot change to HDD with remote. Can change channels manually but that's all. Going mad here!
Hello
Its timer function is ON. Make it OFF. Refer to its user manaul. If you haven't its user manual, try these links to download the user manual to your device. If you feel any difficulty in downloading the same, inform me by fixya comment box alongwith your email address. I'll send a copy of the user manaul to you by return mail.
http://tv.manualsonline.com/manuals/mfg/sony/sony_dvd_recorder_product_list.html
http://www.dataentryjobs.us/67948.html
http://www.ps2netdrivers.net/manual/panasonic.hdc-hs100/
Mar 05, 2012 | Televison & Video
Setting clock
Hello
To set clock:
1. Press "Timer/clock button". The hour digit begins to flash.
2. Press (<< P.DOWN or >> P.UP) on the multicontrol to set Hours.
3. Press SET button. The minute digits begins to flash.
4. Press (<, P.DOWN or >> P.UP) on the multicontrol to set Minutes.
5. Press "Set" button."CLOCK OK" appears on the display. The clock stops flashing, and the clock timer starts from "0" seconds. If the clock is not set "AM 12:00" will flash instead of the clock indication. When the time has been set, TIMER/CLOCK can be used to operate the daily timer recording timer.
If you haven't the user manaul to your set with you now, send your email address to me by Fixya comment bos. I've the downloaded user manual to your set, and I'll send a copy of it to you by return mail. OK.
Jan 21, 2012 | JVC MX-D402T Shelf System
Freezer coil iced up how do put through manaul defrost srs536np
It is probably the timer for defrost that has gone out... some models allow for manual operation of the timer with a large, flat-blade screwdriver it is in the front-center "ceiling" of the refrigerator compartment. The hole is the access for manual turning of the timer. Turn it clockwise slowly until it clicks. Locate the drain tube & if the problem is the timer, water will start draining from the tube within a few minutes. If it is very iced up, it may take 45 minutes to defrost. Then turn the timer a half-turn or so to restart fridge. If you choose to replace the timer yourself, you'll need to manually defrost every day or two, depending on how many times & how long door is open, until new timer arrives.
Oct 03, 2011 | Refrigerators
Friend left RCT100 timer programmed, it comes on the time programmed, but it goes off much earlier than it is supposed to. How can I correct this?
Most digital timer problems can be solved by resetting timer.
Open following link for possible instruction manual with troubleshoot steps
http://waterheatertimer.org/UPM-timers-and-manuals.html#Garrison
Check the following:
Program disable feature is not enabled.
Check 2 different sets of batteries: 1 set AA for transmitter, and 1 set button-cell batteries on back of timer
Choose between 4 different functions: programmable, photocell, countdown, or random
Using programmable mode: make sure there are no programming conflicts
Jul 20, 2011 | UPM Remote Control Timer Set
I have an old electric oven. Somehow after touching the timer settings the oven will now not work. What do I need to set the timer options to. The timer is adjusted using knobs - one for the clock and...
The timer must be in manual mode for the oven to work. Turn the oven ON. With the oven turned on make adjustments to the two knobs. These are generally stop/start timers. These turn and you can also normally press them in. Be patient. When the oven indicator light comes on it will be fixed.
Mar 02, 2011 | Ovens
How do I use SKU: 15112 timer
GE 15112 timer manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15112-Manual-eng-spn.pdf
Same as Tork 652A manual
http://waterheatertimer.org/pdf/651A-652A-manual.pdf
Made for permanent outdoor usage. Outdoor usage only.
Timer has 2 grounded outlets located bottom of timer, maximum wattage for both 1000Watts
50-mini-bulb string of Christmas lights is 25 Watts
Plug timer into 125 Volt GFCI protected outlet.
Do not plug timer into extension cord.
Indicator light shows when timer has power.
Timer turns ON automatically at dusk.
Plug lights, small pump, fountain, motor into grounded outlet located bottom of timer.
Rotate dial to choose timer function.
Rotate dial to select timer function
- ON at dusk & OFF 2, 4, 6, 8 hours later - Rotated dial to number shown on dial
- ON at dusk, OFF at dawn - Rotate dial to dusk-dial
- ON continuously - Rotate dial to ON
-OFF - Rotate dial to OFF
Dec 03, 2010 | Jasco Ge 8HR Mechanical Blk Timer 2 Outlet...
Aiwa NSX-AJ20 CD Shelf System Logo
393 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
