Question about Bosch WFMC 3200 Front Load Washer
Ticking noise in spin
I have Bosch WFMC3200 and when in spin cycle there is a metal rapping/ticking noise. When no clothes in machine and spinning, no ticking noise.
Could be a weak basket spring or shock?
thanks for any help
  • pjb1212 Jan 03, 2008
    No, nothing, very clean inside the basket. The noise is definately coming from inside towards the rear of washer. If I rock the basket by hand from front to rear, I can hear it make metal contact. Sounds just like this metal sound when its spinning. This is why I'm thinking a weak spring. Any thoughts?
    thanks again.
The brackets that hold the top cabinet piece on will rattle quite loudly during the spin cycle as well. Replacing the plastic brackets doesn't always get rid of the sound, as there is some play.
Posted on Nov 09, 2008
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Possible. First run your hand around the inside careful...sometimes there can be an object stuck in the holes and the extra vibration can set it off. common objects are bra wires and hair clips (sorry ladys its the truth) followed very closely by......(you guessed it ladys) Nails
Posted on Jan 03, 2008
  • Rene Jan 03, 2008
    If your machine is under 5 years old I would think not...small possibility. More likely something is loose...quite common in front loaders. The first would be to check all internal brackets starting with the suspension spigots. It does not sound drastic if theres no noise with out a load in it. Trust this will be of some help.
Bosche axxis washer spin cycle ticking noise
Assuming everything else is working normally, I would still suspect there is an object that is getting stuck between the rotating drum and the outer housing. Maybe not coins, but something longer, like a pocket comb or the wire inserts used in some garments. It is easy to take the top off of the unit, and this might help to isolate the noise better. Early spin is usually a bit unbalanced, so it is possible it could also be something really simple like a hose clamp that has sagged enough to be contacting something else, and it only shows up when the machine is bouncing a bit.
Mar 16, 2013 | Bosch Washing Machines
Maytag LAT8426AAM agitator only works in delicate cycle
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
Aug 27, 2017 | Maytag LAT2301AAE
Washer stops during spin cycle
I have the same problem with my washer. If I can figure it out I will let you know.
Oct 03, 2009 | Maytag Dependable Care LAT9706
Bosch Washer WFMC3200.
Contact a Bosch technician. You may have to at least pay for a service call.
Sep 27, 2009 | Bosch WFMC 3200 Front Load Washer
Machine wont spin or drain.makes ticking noise when in spin or wash cycle then stops can you help?
if the timer is still running (ie the ticking noise) and it isnt doing any thing you may have a broken coupling - belt or the motor is shot
Aug 23, 2009 | Washing Machines
Model nbr 110-92580100 ser cd 3347297. wouldnt
your kenmore sounds like it lost the coupler do you feel ok opening the machine and inspecting the part?
the loud noise may be the coupler. I think your timer is working ok. because it goes through the cycle..
If you inspect it to be a bad coupler you can go here and click on the link
let me know
Jun 14, 2009 | Kenmore 22422 Top Load Washer
My kenmore washer Agitates but doesn't spin/drain
your help has arrived!
buy new timer! and install exactly the way you took out with the wires
Jun 10, 2009 | Washing Machines
Ticking/chirping sound during slow spin
it will more than likely be a bra wire stuck between inner and outer drum it will only sound when clothing is in it due to the weight of clothing and water so it wont be heard with just water init or by pushing it around by hand only thing u can really do is eiether strip it yourself or by getting an engineer in but what i would do is leave it after a while it will dislodge itself and go into the pipe underneath the washer in the pipe that is in the middle of the drum check this when the sound stops love
Aug 22, 2007 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
518 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
