Question about Matrix Video Storm CRM84D HDMI, DVI&Component Video Switcher - The 1080p rated CRM84 switches HDMI, ...
Hdmi switcher hey i have an hdmi switcher model chd3hsml and it is constantly switching to the number one position all by itself
  • Anonymous Sep 09, 2008
    Have the same problem.
    Angelo.
  • Anonymous Jan 01, 2009
    I have same problem.
You need use the remote learning method to correct this, for some reason it seems that if you just push the buttons on the hdmi switch box ie, inp2 to switch to a second hdmi output, after about 5-10 min it will revert back, but if you use a infared remote set to switch it, it stays.
Posted on Feb 18, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
What you need is a HDMI Switch with instaport switching feature. I would recommend checking (Part # HDSWTH3D).
HDMI Switch Hi Speed with Ethernet and Audio 3D 4 Port
Posted on Oct 29, 2014
Just purchased alexa fire stick, have only 1 hdmi port on TV, what to do?
If your TV is an older model and only has a couple HDMI ports, but you have several media sources, such as Blu-ray players or video game consoles, an HDMI switcher is exactly what you need. Connect all the media sources to the HDMI switch box via anHDMI cable and then connect the HDMI switcher to the TV.
Jul 30, 2017 | Televison & Video
HDMI&DVI ports already used on LG HDTV.I have X BOX 360 S,has a HDMI plug, can I use a HDMI splitter to plug in the X BOX in the DVI port ?receiving computer via HDMI now
You will not be able to split them, but they do make a HDMI Switcher, allowing you to use your Xbox 360 as number one and your PC as number 2, w you cannot mix both at the same time.
May 02, 2016 | LG Televison & Video
Switch to hdmi
http://lsm-video.en.alibaba.com/
3DHDMI Splitter, 4k HDTV SPLITTER
3DHDMI Switcher, 4k HDTV SPLITTER
3DHDMI Converter,Audio
Splitter,Audio Converter,Audio
Matrix and others AV Products.
You are welcome to contact us today.
Duke Chu
Jan 02, 2014 | Televison & Video
I have a Kramer VP729 video/audio switcher stop getting signal from hdmi 1 and 2 inputs. I have checked HDMI cables they are working. I have turned off receiver reset it to factory settings and reprogram...
The 729 is a pretty old box and only accepts HDMI @ 1080i 1080p. 720i 720p 480i and 480p
Because the 729 is HDMI compliant, and HDCP compliant, you cannot display an HDMI signal on a computer monitor which will not display a content protected source.
Connect your source directly to the display, if that’s ok then try through the switcher.
Check for the latest firmware from Kramer,
You can always call their tech support team.
Nov 24, 2017 | Kramer ProScale VP729 Videoaudio switch ...
What if you only have one hdmi port and it's already being used?
I would try something like this:
http://www.amazon.com/Ultra-High-Performance-Switcher-Switch/dp/B0015YWKYY
It allows you to plug in multiple HDMI devices and send them to one HDMI port on your TV.
Mar 06, 2011 | LG 42LC7D-UB Television
WHERE DO I TURN ON/OFF DOME LIGHT
Check the dome light for a switch that has 3 positions on it. It could be set to always on. Also check the dash light dimmer switcher. That switch that makes your dashboard lights brighter and darker. If it is turned all the way up it has a position that turns the dome light on constant. It could be the other end of the switch so check that and make sure it is in the middle.
Dec 10, 2010 | 1997 Ford Explorer AWD
Turn hdmi2 on
hdmi is auto detecting and shouldn't need to be turned on. try plugging your hdmi1 device into the hdmi2 slot. if switching devices around doesn't get hdmi2 working, that jack is likely broken. all the hdmi ports go into the 1 main board inside, and a lot of times you would have to replace that board to fix. if only 1 jack now works, you could also get an hdmi switcher, and then plug all your devices into that, and then just plug the switcher into the working jack. let me know if I you require further assistance.
Sep 09, 2010 | Samsung LE32A457 32 in. LCD TV
How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Jul 09, 2008 | Denon AVR-3805 Receiver
Hdmi switcher
First check individually if they work ,then connect to HDMI switch ,then change the position of the switch if it is a manual switch or connect the cable to the dish and check the dvd works...............
May 29, 2008 | Toshiba HD-A2 HD-DVD
Televison & Video Logo
418 people viewed this question
Top Matrix Televison & Video Experts
Are you a Matrix Televison and Video Expert? Answer questions, earn points and help others
