Washing Machines
Problem for GE Washing Machines
Generic problem for all GE Washing Machines
Washer will not drain
By nmfeldinor on Nov 01, 2009
washer will not drain GE washer
Solution #1
posted on Nov 01, 2009
Somewhat Helpful)
stefanm597
Rank: Guru
Rating: 87%, 19 votes
If you have a top loader, try this.
If it agitates but doesn't spin or pump, it could be that your pump is seized or something is stuck in it. The agitator is operated by a different motor. Turn OFF the power. and remove the front vertical panel by inserting a drywall knife in a the top right about 4" in from edge at the joint 1" down from the top, push the clip back to release that corner, get another knife and do the same to the left top corner, the pull the top of the front panel and swing towards you, then lift off and remove. Discount the two hoses to the pump, one from the drum the other that goes to the back. Be ready for a considerable amount of water to come gushing out, use a hose to direct to a floor drain. Check to see if something is stuck in the pump or the hoses, remove it. Check to be sure the impeller spins. If you found something restricting the flow or pump, remove it and re assemble. If the impeller won't spin easily, then you need a new pump.
Remove blockage in the pump. Re-assemble and test.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 14, 2009
Not Rated)
ginko
Rank: Guru  Washers & Dryers  Expert
Rating: 89%, 5376 votes
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
On a GE front load, the pump is often accessible from front lower side of machine, on top loader is at the back.
Keep a container ready to collect water when you undo pump hose.
If all the rest is OK, test and eventually replace timer board. Problemwith water pump are far more commonly causing this problems thenfaulty timer board.
Parts and diagrams available here.
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
I am looking for the largest front loader washing machine. I do not want a lot of options just... (More)
Answer
Which are the best front load washer and dryers?
Answer
White marks on clothing after washing. Do not use sta soft anymore. PLEASE HELP!!
Answer
Where is the water outlet filter - i need to clean it! I'd like to clean the water in filters too. ... (More)
Answer
Hotpoint WD420 Washer/Dryer. Drying HighRinse Hold, and Time saver lights steady and power light... (More)
Describe your Washing Machines problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Rockford, IL
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
