Question about GoVideo Cinevision RV4000
"Hi Waiting" message
The player will not play now - the "Hi Waiting" message just keeps flashing. I have unplugged the unit many times and re-powered the unit; the same error persists. Does anyone know how to correct this error?
  • leodonnitt Feb 20, 2008
    So, there is no way of fixing/reparing the unit?
  • Anonymous Apr 09, 2008
    nextbase hometheater 5.1 mp3, vcd can play but some other dvd movie can not. please help
The whole unit is shot.It's the main chip,burned out,coulb be from interupting the upgrade process.thats what I did and called go video and he said,can't be fixed,sorry
Posted on Feb 05, 2008
6ya staff
SOURCE:
Paused a disc ,when i hit play,the play light came on but nothing happened. I cannot turn off the dvd play manually. it seems to be frozen.have chaned batteries
Hi:
Try disconnecting the unit from any power source and waiting for at least 10 mins before restoring power. This should reset the units microprocessor so you can resume playing.
May 01, 2011 | Samsung DVD-1080P7 DVD Player
Message Light
The only thing you can do is unplug the unit from the wall and from the phone line. wait over night and see if this resets the unit. if it does not, I,m afraid there is a circuit problem in the phone and most likely will not be worth repairing, but try to hard reset like I said first. good luck
Jun 11, 2007 | RCA 25414RE3 Corded Phone
Electricity went out when it came back on the standby light (red) flashes cannot turn on -nothing works help
HI:
Try unpluging the unit from AC outlet, and waiting for at least 5 min before plugin in back in this will reset the unit to do a hard reset. If problem persists then it is possible you now have power supply problem.
Mar 10, 2011 | Daewoo DVG-5200S DVD Player
Hp c581 pump mptor stalled .won't print.(anyone have a solution?
If unplugging it for 20 seconds and reapplying power doesn't work...
If the unit is under warranty, call HP at 1-800-hp-invent and they will troubleshoot with you then either replace the unit at no cost to you or send a voucher for replacement value plus taxes.
If it's not under warranty:
try removing all the print cartridges, then unplug the unit. wait 20 seconds and re-apply power
insert the cartridges one at a time closing the cartridge access each time and waiting for the error message to indicate the next cartridge is missing/damaged.
Keep doing this til all cartridges are reinstalled.
If that hasn't fixed it, there isn't much you can do but get another printer.
Feb 26, 2011 | HP Photosmart C5180 All-In-One InkJet...
Lost power while recording a dvd when power came back, i keep getting the "incorrectdisc" error message. I've done the up-channel/play reset/initialization trick several times, but keep getting the...
the "expert's" advice was about as useless as could possibly be- I had already tried all of his suggestions several times before even contacting fixya. what a freaking WASTE of $20.
The only thing left to try is unplug that piece of **** for, oh, say, a month, to let the capacitors discharge completely and hope that the error message goes away. If that doesn't work, the unit is going into the sh*t can.
Oct 05, 2009 | Toshiba DR4 DVD Recorder
Toshiba SD480E HDMI DVD Player will not play flash drive content
hi there!!! i have encountered a unit like yours ,, maybe this solution works,,,,,,if your unit has little reset button at the back panel of the player just push it,,, or in the system set up just restore the factory settings,,,,,,,, i hope that solution would help your problem
Jan 30, 2009 | Toshiba SD-4700 DVD Player
No Link to Base
to re-register the phone, hold down the "handset locator" button on the base untill he "charge" light flashes. then, on the phone, hold down the flash/call waiting button until the LCD screen says "handset registering." if after it registers it says "error!!!" then retry. that is what it says in the instructional booklet, but i have not done this successfully. mine keeps saying error.
Oct 22, 2007 | Panasonic KX-TG2313 Cordless Phone
Dvd player died
Did you check the fuse in the power supply? You have to open the box and its very easy to get to. DS
Apr 19, 2007 | Yamaha DVD-S510 DVD Player
My dvd always shows "system error" and won't play commercial copyright dvds, only recorded ones.
I had the same problem with my recorder except that it wouldnt play any discs at all.. I finally unplugged the recorder and left it unplugged for 16 hours. Now it is fine. I am not getting any error messages.
Nov 23, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Televison & Video Logo
306 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Ekse
Demonic-2011
Demonic-2011
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
