Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Wireless G Plus Mimo
I have tried to set up a WEP encrypted network. My laptops ( i have 2 one with Vista and one with XP) connect fine. When i go to google the first page appears ( not from cache as i have cleared it ). But if i give any search it does not work and 'Page cant be displayed\ msg is displayed. Its happenning with all the site. I mean the home page comes after that the connection goes off. The thing can be reconnected if i switch on and switch off the router. But it happens so frequently ( It works for 30 Sec only ) that it is frustrating. The connection also is pathetically slow. I have a 3 MBPS connection ( i am in Mexico and thats the max ). I think there is some parameter somewhere missing. Please help. My wife is scolding me everyday not being able to chat with her parents :-)
    Novelist:
    Scholar:
  • 136 Answers
With your router you should be using wpa-tsk encrypted network b/c it is stronger encryption and more friendly than wep (wep is old technology)
also check the keep connection on idle settings and change iti to zero so u don't lose the connection
finally check the firewall settings on the router to make sure its not blocking anything.
good luck
smeags
Posted on Jan 03, 2008
6ya staff
SOURCE:
I can't connect the wireless network even it shows that the wireless connection status shows as follows: connection status: connected network duration: going on signal strength: excellent However, the...
Your router's wireless encryption setting (WEP) has been changed.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
May 02, 2011 | Computers & Internet
Wireless security settings on laptop do not match network settings
You will need to change the existing connection to match the "new" settings. I have had this issue with visita as well. If you open the wireless connections, go to advanced settings click on the "saved" SSIDs you can either delete the exisiting one, and start over (easy) or you can modify the settings to match the "new" upgraded system. Visita and XP store these for future use, problem is if one changes it "Doesn't match" so just delete the existing one and recreate it.
If they changed the password for the system or the type of encryption WEP to WPA etc this will correct the issue.
You may want to turn off the IPv6 which can also cause issues with Wifi in some locations.
Sep 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I've installed several different usb wireless adapters (netgear. belkin on a 64-bit vista acer ax1700 u3700a intel machine. They appear to install OK but they cannot find my wireless network. All...
May 01, 2011 | Computers & Internet
I'm trying to log onto my wireless router with my PSP however i need to find me WEP password how do i do this?
The WEP encryption is configured in the wireless settings of the wireless router. Open a WEB browser and type in the IP configuration address of the wireless router and goto the encryption setting to view the encryption code. Then goto the PSP wireless setting and enter the wireless router's encryption code.
Oct 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Icouldn't access the internet. Your help tam, via
Please go in to your router and change the wireless setting from WPA2-PSK to WEP. Ansd then try to connect your laptop.
To windows after you change setting to WEP
(XP bottom right hand side you have system tray in that you have a wireless sign click on it. It ask for the password which you will change put that password click connect)
For laptop also same in case it not work then
(window icon>control panel>network and sharing center>wireless connection>properties>put the password click connect (then it will check out the wireless signal after sometime you will'be able to connect).
Hope this will resolve your issue.
Oct 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hi. I have a Belkin Wireless G Plus MIMO Router, which has been fine to connect my laptop to the internet (although seems slow sometimes). I just got a Wii, but this wont connect to the internet. The Wii...
Check for the wireless encryption settings associated with this. If you're trying to join a network with "Open" settings to a encrypted network it won't work very well.
Nov 17, 2017 | Belkin Wireless-G Plus MIMO Router with...
Belkin Wireless Router/HP Laptop - wireless security problem
This is an unusual problem. It's interesting that you can connect without encryption. A few thoughts, which you may well have considered already:
1) Does this happen even when you deliberately disconnect from the network, and reconnect?
2) The network key/passphrase is case sensitive; it is very easy to make a small slip with this, or some other tiny detail, when entering the key;
3) Is there the slightest chance your router has the same SSID (name) as a neighbour's? ....Sorry if this seems a daft question, but it is something to consider...
Nov 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin wireless G router not connecting PS3
The PS3 should find the SSID of the network, or you could enter it. And then enter the encryption key, be it WEP or WPA. Everything else should be automatic.
Nov 20, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
No connection to internet
What version of windows are you running? 98, 2000, XP, Vista?
Nov 15, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
65 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
