Dometic RM2852 Refrigerator
Problem for Dometic RM2852 Refrigerator
Freezer works fidge dont
By dean_burney on Nov 01, 2009
freezer works fidge dont
Comments:
Nov 01, 2009
- its dometic rv fridge dont know much about it
Solution #1
posted on Nov 01, 2009
Not Rated)
stefanm597
Rank: Guru
Rating: 85%, 13 votes
Some fridges only cool the freezer, there is an evaporator fan motor that then blows are from the freezer into the fridge to cool it. You may need to replace the fan. ($30) It usually starts squealing before it goes. The fan is located in the freezer section probably at the top behind a vented cover. Check to make sure it spins very freely in not replace it. It could be your drain is plugged or frozen, pull out the fridge and look at the bottom to see where the hose enters the fridge, pour some hot water down from inside the fridge to see if it is clear if not, clear the hose.
Was this helpful?
Yes
No
Popular Solutions for Dometic RM2852 Refrigerator
Questions and Unsolved Problems for Dometic RM2852 Refrigerator
Do you recommend Dometic RM2852 Refrigerator?
Answer
Answer
I have a rm2862 dom. it has 12v and 110v power to the ref. the silver case in the back of the ref is... (More)
Answer
the cooling fins in my unit are freezing up. drinks are frozen eggs, are frozen. help me out, can... (More)
Answer
Dometic RM2852 refrigerator, check light. When on electric power the check light occasionally comes... (More)
Answer
freezer works but refrigerator stays around 50-55 degrees....dometic rm2852
Answer
I have a Dometic refigerator model RM 2852. I use it on elec and the drinks freeze and explode in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dometic RM2852 Refrigerator:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
