Question about Admiral AW22 Top Load Washer
Off Balance Our Admiral washer is about 6 years old the past year or so it run off balance all the time I check all the spings and none is broken I leveled it also but no luck. Can you help? Thanks Mike
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
1. Check all the filtration pump and all hose's and connetions there of the most common is a coin where the drain hose connects to the back of the machine.
2. Age of the machine could mean the suspension is getting soft...only fix is 4 new suspention rods.
3. Balance switch Adjustment..most modern washers do not have this thou...not sure for your model
Posted on Jan 03, 2008
Haier top load washer: washes and drains but stops working at rinse cycle. Super capacity model but no model number I can find. The unit is about 6-7 years old.
Call Sears or GE service...either can address the problem. They may offer you a one-year contract, which is worth the price. If they can't fix it, you will get a credit toward the purchase of a new unit.
Nov 02, 2017 | Haier Washing Machines
You could be having a problem with your hall sensor. I would recommend you call Samsung for a warranty service call. The machine should have a 1 year parts and labor warranty so let them fix it for free.
Sep 16, 2013 | Washing Machines
My admiral washing machine goes out of balance a lot
Check machine for level with level and adjust the legs.
Dec 29, 2009 | Washing Machines
8526055 out of balance
There are three spings that hold the tub to the machine. You might want to check those if one or more came off.You'll have to take off the washer cover to access the spings. If one came off it is very easy to put back on. Other than that check your machine body to make sure that it is tight and secure....
Sep 01, 2009 | Kenmore Washing Machines
Washer will not spin dry
Sounds like you have a bad timer. There are quite a few sets of points inside of these. Timer is behind the knob that you set to start your wash. Some of these can be bought off ebay and other appliance repair sights. If you have any mechanical and electrical savvy you can do repair yourself. Usually only tools needed is screwdriver and small socket wrench. Hope this helps Stan
Apr 01, 2017 | Washing Machines
Admiral washer is doing a lot of is level
Possibly a worn drive belt on the underside of the machine, causing the drum not to get to full speed, clothes will be wetter after sping plus vibrates heavily - replace belt.
Tilt machine back for access to underside, simply pull belt off and replace, tension is automatic on motor.
Oct 26, 2008 | Admiral AW22 Top Load Washer
AAV7000AWW washer
sounds like the thrust bearing is worn causing an imbalance on the shaft. check here for a schematic on this machine and parts as listed.. hope this is of some help
Oct 22, 2008 | Admiral AAV7000A
Kenmore washer out of balance
go to and find the parts listing for the 110 model number you have listed above .!retrieve.action;jsessionid=8mJfynqZfmsdSyTnd9kaQw**.shcapp3005?modelNumber=110.16502694+&pop=flush
You might need one of the springs. unplug the washer and take the cabinet off first. look around for broken or missing parts
May 12, 2008 | Washing Machines
Admiral Heavy Duty 22lb. 2 speed motor going off balance
Had Same problem. Replaced The 6 retaining springs and snubber.
$15.00 worth of parts.
Dec 22, 2007 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
144 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
