Question about RCA RT2250 System
Rt2250 how can i stop my rt2250 from jumping in and out with sound followed by a humming noise
  • 1 more comment
  • Anonymous Jan 05, 2008
    Turns on and off then VCR DVD TV do not play at all
    I turned it off for long time and tried again
  • samplerayt Feb 14, 2008
    Unit plays for a while, then the speakers (all) regularly cut on and off about every other second. The unit is long past warrantee, so I opened it up. I don't see anything obvious (bad solder joints, etc).
  • 107 Answers
When it is playing a cd? well I guess your optical lens has a problem.. adjusting the variable resistor at the side of the optical lens (you can find the optical lens inside your unit where the cd/dvd is playing)..
if your using for radio? bad solder is the main problem, and a capacitor is almost going to blow( but it won't blow if it was installed properly). changing it is the best way.
Posted on Feb 17, 2008
6ya staff
SOURCE:
4x4. What causes humming sound?
The used tires may be unevenly worn.
Jan 26, 2016 | 2007 Ford Explorer Sport Trac
Rca rt2250 no sound
please give us more details, I don't know what reciever you want to use? AM,FM? or some other devices.
but if it's the am,fm reciever well you can find it in your instructions manual how to set it though.
just follow the steps and you will have it..
have a nice tunning
just don't rate me badly^^
ps:
make sure your antenna is connected properly..
Feb 17, 2008 | RCA RT2250 System
Car makes a humming electrical noise under hood,when I try to start it just clicks
The humming noise might be your cooling fan(s) coming on with the key in the "on" position. Check your battery connections for corrosion. Have someone jump the battery to see if the additional amps will turn the starter. Sounds like a bad starter though. I would need to know the year, make, model to be more helpful.
Oct 07, 2015 | Cars & Trucks
Humming loud noise
Sometimes depending on what type of tire you have, they can be making the humming sound, other than that you'd have to give more detail as to where you think it's coming from, like the back or the front, the engine or the wheels, transmission?
Jul 02, 2014 | 2005 Ford Escape XLT
My kitchen aid refrigerator model kssc42qms02 making humming noises and the the temp lights are flashing
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 24, 2012 | KitchenAid Refrigerators
98 f-150 2 wheel drive rear end humming sound, all bearings replaced still have noise it sounds like a cupped tire or really bad wheel bearing. not tires it will get lower on decel but noise follows the...
If the sound follows vehicle speed and not the engine you could be hearing u joint noise from the Driveline also. Will get progressively louder with speed.
Jan 25, 2018 | Cars & Trucks
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Stero keeps going in and out
Is this noise in the Tuner position only or in all inputs? Need more info to diagnose.
Jun 09, 2007 | RCA RT2250 System
Rt2250 rt2500 speaker static noise hum buzz until fully warmed up
It sounds like a capacitor in the power supply is just about to die. With the power disconnected have a look at the large tin can looking gizmos near the power transformer. There could be a couple of them. Leave the unit switched off for a while before going near them they could still pack a splat. Replace them with the same value and make sure they're connected the right way and it should solve your problem. Whilst in there have a good look for any other smaller capacitors which look as if they're getting rounded at the top. Replace them too. Either that or dig deep and buy a new one.
Oct 23, 2005 | RCA RT2250 System
RCA RT2250 System Logo
107 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
