Question about KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher
Kitchenaid, kudso1ijbs0, locked out !!!,
Hi, my dishwasher has been acting up, the Add a dish and Rinse only led light up and flash, nothing else will happen, i changed the electronic board about a year ago and that seem to do the trick,Just recently it started doing it again and i replaced the board again,this time it lasted 2 weeks and the same lights are flashing, i have tried leaving the breaker off for about 30 + minutes , still wont work, any ideas? thanks joe......
  • johnnytugs1 Apr 08, 2008
    HI.
    My KITCHENAID dishwasher model KUDI01TJBT0
    S/N FKY602693
    I installed it turned it on, it ran for a 5-10 sec. then stopped, i hit cancel / drain and tried again it started then stopped so i drained it again and then it kinda freaked out with the cancel button going on and off and then the rinse button started blinking and won't stop. nothing else will light up.
    thanks for any help.
    john
  • 1314 Answers
SOURCE: Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Posted on Jan 01, 2008
SOURCE: Clean Light Flashes
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Mar 24, 2008
SOURCE: Clean light flashing 7 times. Can't start the machine
Thank you so much! I have not used my dishwasher for almost 2 years. I called a repair man the first time the "clean" light started flashing. He pushed some buttons, and 3 minutes later he was gone with a smile ( after having left a $100.00 repair bill). I have been contacting Kitchenaid and my dealer for months. No help - no service.
 Nothappy, I fixed the problem with your help. 3 minutes later and the machine is chugging away.  I will never buy a Kitchenaid product again. Not because the products aren't good but - the after service is horrible.
Posted on Jun 30, 2008
  • 188 Answers
SOURCE: We have a kitchenaid dishwasher model#kud102irbl
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 02, 2009
SOURCE: Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Posted on Jun 12, 2009
How do I reprogram the start, rinse cycles? snowflake is blinking and nothing happens when I try to start washing.
[PDF]Download Bosch Dishwasher-Manual - DASH Property ...
www.dashpropertymanagement.com/.../Bosch-Dishwasher-Manual.pdf
Lift tab to open the rinse aid reservoir and add -3 tablespoon max, do not overfill. "qUid rinse aid ... Cancelling a cycle I Reset the dishwasher. 0 LEDs flashing ...
[PDF]Dishwasher Use & Care Guide EIDW6105G - Datatail
media.datatail.com/docs/manual/40243_en.pdf
We view your purchase as the beginning of a relationship. ... Store dishwasherdetergent and rinse agents .... This cycle allows you to program your preferred.
KITCHENAID DISHWASHER REBOOT - YouTube
? 4:17
https://www.youtube.com/watch?v=XJnzzXJcOV4
Sep 17, 2012 - Uploaded by DIYAPPLIANCEREPAIR
KITCHENAID DISHWASHER REBOOT ... Dishwasher Repair will not start - Repair & Diagnostc - Kitchenaid - Whirlpool ... What toDo When the Dishwasher Won't Start - Duration: 5:43. by doityourselfstan 217,315 views. 5:43 ... KitchenAid & WhirlpoolDishwasher - Not Cleaning ,pump wash arm impeller ...
Dec 16, 2015 | Dishwashers
RINSE ONLY LIGHT BLINKING Kitchenaid KUDM01TJBS0
I want to know what was the exact maker/model, part# of your unit
Thanks
Jun 01, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Dishwasher motor starts and stops
Hey Bill,
Not professing to be any kind of a dishwasher repairman but I have had a similar issue with the start and stop thing and it turned out to be the timer motor had started to go, and in going it 'burned' a couple of sets of the contacts as well. Check with a local appliance repair centre and see first if they agree with me, and if they have anyone who can rebuild the timer - Typically not too hard to get access to and remove - In my case in Canada, it had to go to Toronto pre-paid but $70 was cheaper then a new dishwasher and it's worked great for years
Feb 09, 2014 | KitchenAid Dishwashers
Normal Cycle Led Flashes and add a dish flashes with two blank lines in time window. Nothing responds. Model KUDP01DLBL3
Hi
Thanks for using FixYa. This issue can be either due to a faulty door latch or door lock switch which is not engaging itself. And, if the door latch will not engage the dishwasher will sense it as open door and will not start the cycle.
The light also blinks when the dishwasher detects a no-fill condition. You’ll need to get access to the fill valve by removing left panel, look at back to see where valve is when you get to it remove one of the wires and set meter to ohms setting and put a lead on each tag on valve. The reading should be about 3.6k ohm if you don’t get a reading then the valve is at fault. I'll also suggest you to check the detergent dispenser solenoid. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 03, 2010 | KitchenAid Dishwashers
Greetings from Downunder, i have a HDWSE12 dishwasher Rinse aid light flashes all the time and it won t go. I put dish liquid in rinse aid container - still flashes. Don't normally have to use rinse...
the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
Mar 04, 2010 | Dishwashers
We have a kitchenaid KUDS25SHBL1, serial number FK1130619. It doesn't work well and we think it might be old. It came with the house, so we're not sure the year. How can we tell? We appreciate your help:)
Residue left on dishes after washing. Looks like mineral deposits. Unsure if this is a dishwasher or water softener problem. Also rinse aid dispenser not working. Light that tells you to add does not work.
Oct 24, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher Logo
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
