Question about Optoma MovieTime DV10 Multimedia Projector
Picture turns blue
After about 45 minutes the picture changes into a blueish tint. It seems like no other colors are showing except various shades of blue that make up the picture. The picture is not distorter in any way, the colors are just off. If I wait for a day, for instance, and then turn back on the projector and play something, it will play fine but then turn blue again after around 30-35 minutes. My bulb is on 1000 hours.
  • quinzoto Feb 19, 2008
    i have the exact same problem! could you fix it??
  • 167 Answers
Bad Lcd's i guess get the projector looked at immediately before something worse happens
Posted on Jan 26, 2008
  • anonymous anonymous Jan 26, 2008
    no wait it's a dlp projector. i think you might need a new colour wheel because it might have stopped
Mits. rear projection tv ws65905 picture has blue color tint
Your blue picture tube is failing. Invest in a new TV. "If" you can find a new set of tubes(you have to replace all 3 red blue and green) they are around $800-1000. Not cost effective. Run the TV into the ground if you want to wait but do not invest any repair money in my opinion.
Jun 01, 2015 | Mitsubishi WS-65905 65" Rear Projection...
Picture has red tint
I would unplug it from the wall for a while and see if that will help reset it. Also make sure there are no magnetic devices near the screen because this will change the screen color as well. Mine will mess up every once in a while so I just unplug it while I am off running errands, plug it back up when I come home and it seems to reset itself. Good luck
Jun 15, 2014 | Emerson EWF2004 20" TV
Green picture
Hi Lizzette,
I am afraid your problem is a little technical. Well if you know something about lcd tv technicals, the problem seems to be the T Con board and/or its connectors. Check the ribbon cables and connectors, clean them properly and and start the tv.If it is not possible or it does not work, please consult someone qualified to handle your set. Good luck.
Dec 18, 2013 | Samsung 46 in. LCD HDTV
I can't seem to correct a tint problem. The tv turns on and the tint doesn't change. A friend says it could be a vidoe card?
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Nov 08, 2009 | Akai PDP4225M 42 in. Plasma Television
Sounds like a bad blue CRT (picture tube) ITs expensive and difficult to replace. CAll a Sony service center for an estimate. but expect to spend $500-700 to replace it.
Feb 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Bad Picture Blueish picture
If the red gun stops working it could make the picture very blue-greenish. This could be caused by a number of problems, including a coolant leak, but it's most likely a bad electrical connection somewhere in the set.
Best left to a professional repair guy, frankly.
Mar 19, 2008 | Samsung HCM5525W 55" Rear Projection...
Color problems at top and bottom of screen
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
Dec 17, 2006 | Hitachi 42V715 Rear Projection Television
Optoma MovieTime DV10 Multimedia Projector Logo
469 people viewed this question
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
