1999 Land Rover Range Rover Logo
Posted on Nov 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My battery died I replace the battery and now radio do not except a code.
Harvey N Tawatao
Level 3:
  • Master 3,854 Answers
  • Posted on Nov 01, 2009
Harvey N Tawatao
Master
Level 3:
Answers
3854
Questions
0
Helped
2796748
Points
16501
If the radio will not except the codes because radio codes was attempted to many times, you can reset the radio by disconnecting the battery for 30 seconds and the radio will reset it self for you to re-enter the radio code. Good luck and keep me posted.
1helpful
Ford Fusion 2012 radio quit. All I get is the word Ford Fusion on the display. After a week my battery dies.
You may need the Factory Setup data (codes) to unlock the radio. That should be in your manual.
2answers
Turned radio off then battery died, got vehicle fixed but no power to factory radio, all fuses check as good. Is there a trick to getting the radio to turn on again?
when the battery dies or is removed , the anti-theft code of the radio kicks in and the unit will not work again until a special code for that radio is reinstalled
the code could be in the user manual in the radio use section ,or there are sites on the net that may have the code for you
My Hundai Tucson died today, jumped it off fine and it started right up. Now all the dash lights come on except for just the radio screen and button lights. What do I do?
HI,
Look in the Owner's Manual for information on what is required if your car's battery is replaced - Yours wasn't replaced by did lose power. Likely a code needs entered - into the radio- to fix the issue.
GL,
Td
Why wont radio work after replacing battery?
by replacing the battery the anti-theft code requirement has been activated
check the radio forums and comments on this site as there are ways to recover the code
1helpful
My battery died so i replaced it and now my radio won't come on. Tried holding down power button, turning on and off ignition. Still has no power. the battery was out of the car for about 4 hours.
If your radio has anti-theft system you will have to go to the dealer and get the accss code to reactivate the radio if you dont have the code already. GM vehicles with anti-theft radios will lock when power is lost to the system if the radio is not turned off prior to battery disconnect or dying.
Radio doesn't work after battery died, recharged and later
hi.
find your radio here...http://www.ibiblio.org/tkan/audi/radios/radios.html
then follow link for program instructions
good luck
2helpful
2answers
Porsche radio code
You need to recover the radio's serial number to decode the 4 digit radio key. The full process and decoder is available here: Porsche Boxster: Online Lost Radio Code Recovery Tool
1helpful
Need default radio code for 1991 volvo, battery died
There is no default code, the are unique to the radio. You will have to go to the dealer to get this code.
Powerlocks
i shoul not afect any thing unless you replace the batterie with the car runing, and some radios have antitheft code if batterie die or disconect the radio will ask you to type a code in order to work again but most of times it display the worl code on the digital screen
Top Land Rover Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Land Rover Expert? Answer questions, earn points and help others
