Question about GE (PSS26MSRSS) Side by Side Refrigerator
No ice My freezer will freeze up on the back panel,will not make ice cubes but the water will dispense., the refrigerator side (of the side-by-side stays warm. Where do I start? I've defrosted,shut everything off, changed the s4ettings,on both sides, but does not work? Any thing I can do,besides buy a new side-by-side? Thanks.
  • 33 Answers
When you say freeze up on the back panel are you reffering to the back wall of the freezer side of the refrig if yes you can start by removing that same back panel there you should find what looks like snow this must be defrosted fully with a blow dryer make sure that the refrig is unplugged before you start. if you have an ohm meter this would help find the defrost heater its a glass rod w/a wire element passing through it it runs the width of the refrig freezer check for any signs of green corrosion the glass shouldd be see thru if its cloudy chances are its bad unplug it / them from their terminals put your ohm meter and see if its good if its bad replace both. if not i will check tomorrow to see if were on the same page
Posted on Jan 03, 2008
My icemaker stop working but the water dispenser still working I check both water lines from the filter its ok but can't check the freezer line by icemaker. turly don't know why the water will not flow...
If there is no ice in the ice mold of the ice maker, you can pour enough water in to make cubes, wait an hour or so for the icemaker to cycle.( freeze and dump the ice). If it does, then your water valve on the back of the refrigerator that the main water line hooks up to is bad. Replace it. The valve has two sides to it. An ice maker side and a water resevoir side. One side can be bad allowing the other to work.
If the ice maker does not cycle and dump the cubes then you probably have an ice maker problem.
Jun 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Mar 21, 2009 | LG LRSC26910 Side by Side Refrigerator
Ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Mar 15, 2009 | GE Refrigerators
Water does not reach ice tray, ice maker appears to be cycling
Pull the filltube from out of the back check for ice inside, use warm water to melt.
Mar 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water line to water dispenser is freezing up inside the freezer
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 27, 2008 | GE GSL25JFPBS Side by Side Refrigerator
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Nov 26, 2007 | LG LRSC26925 Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
52 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
