Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Problem for Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with...
Fridge acts like compressor is not coming on -
By sixblubaughs on Oct 31, 2009
Fridge acts like compressor is not coming on - Maytag wide by side - seven yrs. old
Best Solution
posted on Nov 01, 2009
Very Helpful)
aasc
Rank: Guru  Maytag Refrigerators  Expert
Rating: 93%, 556 votes
Pull the refrig out and remove the back panel . You should see the compressor and the cooling fan ( condenser fan ) . If the fan isn't working , it needs to be replaced . If the compressor isn't running or starts then cuts off , then the box plugged onto the side of the compressor , with 3 wires going to it ( overload/relay ) needs to be replaced .
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Not Rated)
the dr
Rating: 90%, 757 votes
Probably bad Compressor PTC relay
Was this helpful?
Yes
No
Popular Solutions for Maytag 25.6 cu. ft.
Questions and Unsolved Problems for Maytag 25.6 cu. ft.
Do you recommend Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water?
Answer
Answer
what is the correct temperature for the fridge side of a wide by side?
Answer
my refrigerator has stopped cooling, is there anything I can check?
Answer
We have had several problems with our MSD2756GES side-by-side frig (mostly related to the ice... (More)
Answer
the external water and ice cube dispenser still dispense after pulling away. is this a stuck switch... (More)
Answer
first the climate zone drawers started getting too cold and freezing everything,I turned the drawers... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag 25.6 cu. ft....:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
