Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Problem for Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Kenmore microwave oven model 665 4438955 just
By acvillarreal on Oct 31, 2009
kenmore microwave oven model 665 4438955 just stopped working, I wonder what happened
Solution #1
posted on Nov 01, 2009
Not Rated)
downhille
Rank: Guru
Rating: 90%, 47 votes
I am not familiar with this particular model, however there are a few things you could check. Do you get any lights or indications at all? Inside (unplug before removing cover) there is probably a fuse. If it is blown, you can replace it as it might have been blown by a power surge, however you should check to see if there is another bad component, especially if it blows a second time. There is generally a transformer, a capacitor and a diode in the power supply, and a magnetron that does the real work. If anything is burned or blackened, this may be your problem, or it could merely be an indication of another shorted component. Using a multimeter, you can check the magnetron. Measuring between the two terminals, you should see very low resistance. This is the filament. From either pin to ground you should see infinite resistance. Anything less and your magnetron is bad. The diode should measure relatively low in one direction and infinite or close to it in the other. The capacitor should start low and build to infinite (as it charges). Most people should just replace the fuse, if bad, and let a technician find any other problem. My built in was worth ordering a new magnetron. Some of the cheaper counter top units might not be worth fooling with. I hope this has helped you.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24 in. 17482 / 17484 /
Questions and Unsolved Problems for Kenmore 24 in. 17482 / 17484 /
Do you recommend Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher?
Answer
Answer
The dishes on the top rack do not come clean. The spray holes are clear.
Answer
the quick rinse light keeps blinking - but the machine won't start. Kenmore Elite Dishwasher - type... (More)
Answer
I have a Kenmore Elite dishwasher and the under counter mounting hardware/bracket has broke. It... (More)
Answer
I have a Kenmore Elite Dishwasher that is 3 yrs old, which cost $1000. On the top dish rack one of... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 24 in. 17482 / 17484 /...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
