Acer Aspire E360 PC Desktop
Acer e360
shared by 2 users
posted by photomax007 on Jan 03, 2008
can you hook this to a tv and watch a movie. thanks howie
Comment posted on Jan 03, 2008
THIS IS PHOTOMAX007 AGAIN, THIS IS ABOUT THE ACER E360. IT HAS A YELLOW PLUG IT CONNECTER ON THE BACK OF THE MODEM. DO I PLUG THE WIRE IN THAT AND THEN INTO THE TV, TO WATCH A MOVIE COMING FROM THE COMPUTER. DO YOU WATCH IT ON AVI ON THE TV OR IS THERE SOMETHING I HAVE TO FIX ON THE COMPUTER SO IT WILL SHOW UP ON THE TV. THANKS HOWIE
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by amosnew2003 on Nov 26, 2008
Acer Aspire E360 network driver
Where can I get the above PC network driver?
Best Solution
Helpful (85)
TeK Micro
Rank:Guru Guru
Rating: 89%, 48 votes
If you TV has a DVI input on it then you can.
Basically this means that your TV has the same connector that your computer LCD is currently connected to on the computer tower.
Rating Locked! (?) photomax007 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on acer e360:
I don't want to Accept this solution
Solution #2
Not Rated (0)
2bob_watch
Rank:Wiz Wiz
Rating: 81%, 45 votes
there is another way of making your computer a television. If you go to the shop and get a usb contraption that picks up your tv signal and plays it back on your screen. It's efficient and wireless so you're not tripping over cords. The wired way requires you to have an antenna input whereever your computer is or close by. I hope this helps
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these PC Desktops problems?
PC Desktops
I have a gate way m3 series and I have lost the ability to...
PC Desktops
i have a um175 usb modem and i am with verizon. I also...
PC Desktops
after installing xml spy entedition 2008 we lost the...
PC Desktops
saitek keyboard lightsupwhewindow booting then shuts down...
PC Desktops
lost key code
Loading problems.
Repair Service
Find PC Desktop Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
