Question about Compaq Presario X6000 Notebook
My laptpb is no power on
After problem short in the connector screen in the motherboards
  • Anonymous Jan 03, 2008
    i want to know service center of compaq in mumbai
  • 619 Answers
Visit to : you can find the solution
Posted on Jan 03, 2008
Device could not start
what device? is *********** board won't start? Or a hardware doesn't start like ram or your printer
If the problem is your motherboard check all your hardwares and connectors like this:
  1. If the motherboard won't start if you click the power button check the LED(the small light bulb on your motherboard) if its glowing. If not, check the connector of your power supply or check the power supply if its working by looking its fan if revolving.
  2. If you push the button and there's a sign of power but didn't start up that will appear on your screen check the connection of your monitor screen to your desktop computer. If it's connected, remove your RAM from the motherboard and insert it to another memory slot to check if it's broken.
  3. Last, if you push the power button and here 1 short beep but the boot screen didn't appeared from your screen check your graphic card. Remove the graphic card and re-insert it again to its graphic card slot and plug in your monitor connector to it. If it still remain that way, buy a new graphic card.
Aug 01, 2011 | Computers & Internet
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
No connexion with the screen screen is black
first remove the cover of your computer after switching off the system and removing the power plug the power the system and see whether the processor fan is working if not power off the system and remove the 24 pin connector from the smps to the motherboard and short the green and black pin of the conector from the smps and see the smps fan is working if not replace the smps if working then remove the memory from the slot and clean them or change the memory to which match the dimm slot an connect the connector and switch on the computer
Feb 27, 2011 | ASUS Computers & Internet
Abit kn9 sli, my problem is this, when i turn my pc on the fans spin for about one second then it all turns off. the power lights on the motherboard stay on but it wont power up at all. if i turn the power...
Are you sure the 4 pin connector is going in correctly? Some motherboards have an 8 pin socket, and the connector can be placed in improperly. The symptoms you describe indicate a dead short on the power line when plugged in.
Jun 20, 2010 | Abit KN9-SLI Motherboard
Install IDE devices (drives / DVD / CDROM) sata
IDE devices have different "data" and "power" connectors than SATA drives.
So, you need a motherboard with IDE connectors, if you wish to connect an IDE disk-drive (or CD/DVD), and you need a motherboard with SATA connectors, if you wish to connect a SATA device.
Similarly, the connectors on the power-supply must be compatible with the sockets on the disk-drive (or CD/DVD) drives, so that the devices can get power.
You could possibly purchase a short IDE-to-SATA power-adapter, if you have a SATA device, but there are no SATA power-connectors on your power-supply.
May 29, 2010 | Intel Motherboard
AOpen AX4BS motherboard front panel connections & power on.
That model motherboard does not support on/off control of the power supply. Refer to the output diagram on the power supply, and there should be pins in the connector (not used on your board) that may refer to the on/off control. Those pins should be tied together. Then the PC will turn on via the main power switch, and will require a manual turn off when the display says its ok.
Oct 24, 2009 | Acer AOpen AX4BS-V (91.89J11.001)...
Low or no voltage for the two fan connectors on the motherboard. Fans will not run when attached. Have to use a direct connector from the power supply. All voltages from the power supply check okay.
there might be a short on the mother board where the fan connectors are.try different fans.if they don't work then there is a short.the fans work the same way on the lines from the power supply.
Aug 04, 2009 | Tyan Trinity KT S2390 Motherboard
New pc build. crashes randomly shortly into bios screen
Can you describe your hardware (brand names a part numbers of the hardware and speed)Do you here beeps at the post. Here is something you can try. Remove the motherboard with the processor, memory and video card if you have an external one left in place and connect the power supply.Make sure all your power connectors are in where they need to be. Somtimes there are as many as four connectors from the power supply to the motherboard.Make sure everything is indexed and seated properly. See if it works up to the no operating ayatem error. If not use only one memory stick and try that. Still nothing try one of your other memory sticks only if you have more than one.If nothing and you have a onboard video card enable it in the bois and remove the external one and try that. It micht get you going. A common problem with new setups is a standoff connector that mounts your motherboard to the case is in an unused position and shorts the board at that spot.
Nov 30, 2008 | Computers & Internet
Power problem
Please do NOT TRY TO SWITCH ON your comp in same condition again as you would be damaging it further. Its not your power supply alone there EXISTS A SHORT CIRCUIT IN OTHER COMPONENTS as well . The SHORT CIRCUIT Protection circuit of your Power Supply senses this and switches off preventing further damage . Well you could try this - Disconnect power to all the componenets like HDD , CD/DVD , MOTHERBOARD and FDD etc.,. Plug in the AC input power to your Power supply and on the 20 pin connector look for green colored wire and black wire on the same connector and short these 2 wires ONLY with a metal paper clip or a piece of wire , if the fan in the PS works and spins at full speed till you disconnect or remove the short between the two wires (Green and Black) then your PS is Working FINE . Now connect each of the component's power connector only and repeat the same exercise you will be able to identify which component is shorted.
May 01, 2008 | EliteGroup P4VMM2 Motherboard
Compaq Presario X6000 Notebook Logo
66 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
