Try disconnecting the 120VAC power cord for a few minutes then re-power back up if you haven?t already tried that. If you still have the same issue then you may have a failed Control Board. If it?s the FAV6800AW is there an error code in the LED display? If the machine will not d let you into Service Mode then my next step would be to replace the Control Board a 10 minute job. If you decide to call in a service repair company I would call Maytag for an authorized Maytag repair service in your area. Some parts like the Control Board may still be under warranty (5yr). Warranty info is in the SM link I attached. The number to call is 800-688-9900. Maytag will need your model number and serial number, that info is located on the back right top side of the console. The Service Manual for reference. Sears Parts Direct for reference. Post back if you have questions or want to dig deeper into the issue
Comments:
Nov 01, 2009
- Sorry I forgot to attach the Service Manual link
Have a front loading Neptune, not all the water is being spun out at the end of the cycle. The...
(More)
Have a front loading Neptune, not all the water is being spun out at the end of the cycle. The heavier the load the more water that is in the drum. When clothes washing it sounds like it is dragging. Don't know if it would be a motor or the pump.......Help...Larry
Maytag washer will not lock and start I read some reviews about the top loading Maytag washer and...
(More)
Maytag washer will not lock and start I read some reviews about the top loading Maytag washer and several said they had to replace the circuit board and it still did not work. The insturctions say there may be a loose plug. But the more indepth explanation said that its the Continuity between p.6 pin 1 and p.8 pin 1 on the circuit control board. I ordered a new circuit board and can return it in 30 days if not needed. However this Maytag is supposed to be able to reset itself. Any suggestions.
My clothes are stuck in my neptune. It won't drain and the door will not unlock. How can I restart...
(More)
My clothes are stuck in my neptune. It won't drain and the door will not unlock. How can I restart it?
