Question about CTX Optoma EzPro 600 Multimedia Projector
Blowing fuse Ctx 600 keeps blowing  fuse. any suggestions?
  • 4 Answers
USE A HIGHER AMPERAGE FUSE AND IF YOU AREN'T AFRAID OF FIRE, JUMP IT.
Posted on Sep 28, 2008
Why does the fuse blow just assoon i turn ignition on 600 yamaha 600
Hi, Tony you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue, please visit the websites below. Good luck and have a nice day. https://www.tradebit.com/filesharing.php/search/0/yamaha+600
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 10, 2015 | Yamaha Motorcycles
Honda Hornet keep blowing dash fuses
Check for a short in the wiring. Sounds like after bumping along on a ride an exposed wire grounds and blows the fuses.
Apr 13, 2015 | 2001 Honda CB 600 Hornet S
Exactly what can blow the main fuse
Hi, Anonymous you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Main Fuse Blows The FZR Forum
View topic 92 FZR600 Keeps Blowing Main Fuse
https://www.tradebit.com/filedetail.php/2864660-yamaha-fzr-600-service-repair-manual-pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Apr 24, 2012 | 1991 Yamaha FZR 600
1999 Honda CBR 600 F(4)X keeps blowing the main fuse
Hi, Robert before diagnosing your blown fuse issue, check the bottom of your seat, if its metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) You are going to need a wiring diagram from your service manual, a test light, an ohmmeter and plenty of extra fuses.
If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
If you driving down the road for 30 minutes or 15 miles and blow a fuse you have soft/flying short and may take some time and patience to find.
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with an ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Blowing the main fuse help CBR Forum Enthusiast forums for Honda CBR Owners
http://www.fireblades.org/forums/honda-cbr400rr/87007-main-fuse-blowing-instantly-all-time.html
Honda CBR600F4I 2001 Service Manual
Honda Motorcycle Wiring Diagrams
https://www.partsfish.com/page/oem-parts-for-honda
Honda CBR600F4i Owner Manual
Mar 13, 2012 | 1999 Honda CBR 600 F(4)X
Car audio amplifer blowing fuses
why are you in stereo for subs? mono all the way.
Feb 21, 2010 | Kenwood KAC-7252 Car Audio Amplifier
Keep on blowing tail light fuse
The wiring to the tail light needs to be checked its grounding somewhere.
Trace it from the rear to front.
Sep 19, 2009 | 2001 kawasaki ZX-6R Ninja
Projector Cable
Found a pin-out at: http://www.diyaudio.com/forums/diy-projectors/78108-ezpro-550-rgb-cable-pinout.html
1 2
2 5
3 9
4 No conectar
5 14
6 1
7 6
8 13
9 15
10 11
11 no conectar
12 No conectar
13 3
14 12
15 No conectar
You probably need to have a special cable made up.
Jun 24, 2008 | CTX Optoma EzPro 600 Multimedia Projector
Ctx ezpro 600
Yes it is. You have knocked one of the optical components out of alignment. This should be a fairly easy repair for a qualified tech, well worth it, considering how expensive video projectectors are.
Jul 12, 2007 | CTX Optoma EzPro 600 Multimedia Projector
CTX Optoma EzPro 600 Multimedia Projector Logo
101 people viewed this question
Top CTX Office Equipment & Supplies Experts
jasbo
jasbo
chinopuma
Level 1 Expert
Arora Singh
Arora Singh
Are you a CTX Office Equipment and Supply Expert? Answer questions, earn points and help others
