Question about Soleus KFR-18 Air Conditioner
Soleus KFR-18 Air Conditioner Problem
In the heat mode out door fan cut off
  • Jack123xxx Jan 04, 2008
    In the heat mode out door fan cut off,I can take the tube sesor
    out of indoor unit it work find,bout line get too hot to touch.
    when I turn to cool mode the small line freeze up and it dose not
    get cool.
  • Jack123xxx Jan 07, 2008
    Comment by Jack123xxx, posted on Jan 04, 2008In the heat mode out door fan cut off,I can take the tube sesor
    get cool.This New if the air intake is more than it can handle will this cause a problem,the mini split is in a sun room and its not
    Insulation will this cause a problem
    Problem Solver:
  • 9 Answers
All of the kfr series have a indoor coil sensor that monitors the tube temperature. In the heating mode it will sense for high temp and cut off the outdoor fan to try to lower the indoor coil temp. The cut off temp is 129f, when the coil cools down the fan will cut in and start developing heat again. If the coil continues to get warmer it will shut off completely. The system is either overcharged or the coils and or filters are dirty. All Soleus units need both lines insulated seperately and not together because the metering device is in the outdoor unit. Have your tech calibrate the charge and make sure you clean your filters every 3 months. Removing the sensor will cause the indoor coil to get too hot and possibley start to melt your housing. For further technical questions pleas call 626-378-1518 for technical questions,,professionals only.
Phil
Soleus Tech Support
Posted on Mar 13, 2009
  • 236 Answers
Check your thermostat settings at heat mode.
Posted on Jan 03, 2008
  • Felizardo Erilla
    Felizardo Erilla Jan 04, 2008
    The unit have a freeze up sensor, line freeze up is the cause of tripping of the unit.
    For this problem you need a qualified technician to repair the unit.
    The cause of freezing the line is, maybe there is a leak and the amount of the refrigerant in the system is not sufficient and that is the cause of the icing of line. And the freeze up sensor protect your unit to avoid severe damage.
Soleus gb-pac-08e4 h8
The unit is NOT pulling water from the air to cause this error, yes they pull moisture out of the air and over TIME fill with water. The problem is that the unit shows the H8 error even when empty. Worked for 2 months and now just keeps popping the H8 code, EVEN THOUGH IT IS EMPTY. Unfortunately sometime you find out after buying a product that it is not quality, that is the case with Soleusair. Bad company, Bad product.
Jun 17, 2012 | Soleus KFR-18 Air Conditioner
KFR-12G New Compressor.....Draws too much amperage now. As though it is in the start mode all the time. New Capacitor too. Not overcharged either. Wiring is as it was originally. Thanks in advance.
Well, I looked at the date of post, doubt, you still need help, But, you can try a hard start kit. A generic one will do. It may decrease the life of compressor though
Oct 27, 2010 | Soleus KFR-12G Air Conditioner
Soleus kfr 18gwda
The fan blade can be purchased by calling 1-888-8soleus.
Mar 11, 2008 | Soleus KFR-18 Air Conditioner
Air conditioner
Go to any BOC Gases outlet and view their range of aircon fans. Depending on model $100 to $200. Fans are not an expensive item.
Allow an hour or two of labour (in case there are problems)
Jan 05, 2008 | Soleus KFR-18 Air Conditioner
Solebus heating
yes, it is intended that way. I also have a Soleus and a special manual addendum sheet was inside the manual and it pointed out this feature..I think Soleus had a lot of customer phone-ins over this...I guess the idea for the exhaust is to withdraw moisture from the room, since anytime air is heated or cooled, moisture is a by-product that must be eliminated.
Nov 03, 2007 | Soleus KY-34 Portable Air Conditioner
Soleus KFR-18 Air Conditioner Logo
3,695 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
