E701 is reported when the controller is unable to communicate with the IOT(image output terminal).The following check might save some further troubles. 1.If the the controller is pretag 2,connect a terminator to the SCSI port marked "HOST" 2.Disconnect the IOT,power up the controller,press the reset switch on the controller board and allow reset cycle to complete,power down,reconnect,insert floppy firmware,power up. 3.Down grade to firmware 2.7 4.Check PSU +5V and +12V at the pcb. 5.Check HD drive present on the config printout. 6.Check reset switch if not stuck in on controller. 7.Check controller to IOT cable in good condition. 8.Replaced the flash SIMMs And lastly if all the above fail to cure the fault then replaced the controller board.
Comment posted on Jan 03, 2008
Let me do a little bit more research. Thanks for the feedback.
Does your copier have a sorter attached? If so you could possibly remove it and put an output tray at the exit section.
E7-01 looks like a sorter bin travel error. I'm trying to confirm this information. I don't want to post, prematurely, any incorrect data,I simply want to be as expeditious as possible.
I will post an update asap if I find other information related to this issue.
Rating Locked! (?) jakeami has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Panasonic FP-7735 error E7-01:
