I just upgrade to Window 7, to my ACER AspireOne Netbook. Successful install with no problems. I have Acer X163W Monitor to use with my Acer Netbook, before install Win 7, I was able to setup the monitor resol at 1268x768. Now with Window 7 it only goes 1040x600 ex. How can I get the Acer X163 driver for the monitor to work with Window 7 setting at 1268X768?
You can try installing this in Windows 7 using compatibility mode and see if it works. Otherwise, just try to contact them directly or try and submit a query about it.
What is the difference between a NEC 1880 SX and a NEC 1810 SX Monitor? ALSO What is the difference...
(More)
What is the difference between a NEC 1880 SX and a NEC 1810 SX Monitor? ALSO What is the difference between a NEC SX and a NEC FX monitor?
I inherited this nice monitor but it will not power up! I am sure it has the correct power going in...
(More)
I inherited this nice monitor but it will not power up! I am sure it has the correct power going in but get no lights or sounds at all. Can use the same power cord to a diiferent monitor and it comes right up, so the power in is ok. I am using the RGB connector but it doesn't even get power to the unit at all it seems. Is there a fuse or capacitor that might need replacing? Does anyone have a similar problem? This monitor was sitting for a few months but was supposedly working ok before it was stored.
I just noticed today that there are faded dark patches after all the text and images on my screen....
(More)
I just noticed today that there are faded dark patches after all the text and images on my screen. Is my monitor just bad or is there a setting to fix this?
