Question about Brother MFC 3100C All-In-One InkJet Printer
Inkjets my machine keep saying to change the yellow press 1 or 2 i have done this and cannot make this stop i tried to clear it so i can change the date. i have even tried to unplug it and plug it in. please help
Press stop colour black and start button together .. and follow direction
Posted on Apr 07, 2008
Change ink color
first you have to drain the ink... to do this after making a master with a heavy image on it.
1. turn off the machine and start it up while holding left and right print position buttons. when machine starts up you will see a number ... press the c or stop or yellow clear to reset that to 0000.
2. place paper in the paper tray and enter 888 and press start.
3. the machine will start printing .. let it print jntil the image is very light and press stop.
4. press the c clear or stop button to reset display to 0000
5.place the new color you want into the drum and enter code 890 and perss start.
6. hold down the yellow reset button u til the machine restarts.
7. all done! but please note you will have color mixing and banding for a few thousnad copies until the old color gets purged, there is no way around this.
Jun 14, 2013 | Riso RZ390 Duplicator
Error Code P-04-513
P04-513 is an ink overflow error.
the easiest way to fix it is to run the drum dry.
here is how:
1. turn the machine off by the power swith.
2. hold the left and right print position buttons and turn on the machine.
3. when the machine starts it will show you some numbers.. perss either the clear or yellow reset button to show 0000
4. now enter 81 and press start and the machine will make a master.
5. once the machine is done press the clear or yellow clear button to return to 0000
6. next make suer you have plenty of paper and enter 888 and press start.. the machine will start making copies of the test pattern. (if it jams a lot you may want to use speed 1 or go to step 4 and use code 80 instead)
once the copies start coming out light you can press the stop button and when the machine stops turn it off and back on normally.
Dec 19, 2012 | Riso RZ390 Duplicator
Risograph having error code t95-056
this is a serious problem .. this means that the serial # on the boards for your machine dont match.
you can try this but it may not work. turn the machine on holding the left and right print position arrows. press the yellow clear button 1 time to bring the display to all 0000
then enter the following codes eactly as i say or you can do irreversible damage to your machine.
enter 9874 and press start. you will then see a number on the screen i usally see 51 press the yellow clear button to clear that number and bring the display to 0000 again (if yellow clear does nnot work try the orange stop button or the c button on the bottem of the keypad.) when it says 0000 again enter 1198. when the machine beeps and shows you the 1198 again turn it off by the power switch and turn it back on normally. if this does not work you will need a technican to come in and fix this problem
Jul 09, 2011 | Office Equipment & Supplies
What mean code f35-3 on konica 7020.
f 35-i thru f35-6 low temtemperature or open thermistor
simulations note : 9272 is the standered password to enter simullation press9,2,7,2,start , to use these with power already on press and hold the"*"key util the display says "please enter service password"note:factory manual says"keep pressing" this might mean hold down or it might mean press repeatedly.press9272 start "mode selectmenu screen" will appear.press the mode you want[p ,25, 35, 36 , or 47] when finished press "normal mode"to return to standard screen use the number keys to change values press print key to check item press "stop/clear"when finished
"25 mode" to enter this mode turn power off, press the 2and 5 keys and hold them down while they are held down turn on power menu screen will list choices 1 software switches 2pm count 3collectng 4 5 select your choice enter value press"return"to see that your new value has been entered turn power off new in formation will not take effect util power is off and back on again 1 software sw ....use up/downarrows keys to select dip switch use up/down arrow keys to select to select bit number"on"is 1 "off" is "0" on will set bit off will clear bit press "return"to return to menu listing dipswitches and all their bits cannot be done in a short publication such as this one dipswitch 3 bit 1 is the fuser reset command {for error cdes f34,f35and f36}0 is no 1 is yes to reseta fuser fault you enter this mode select dipswitch 3, select bit 1and change "1"to "0"by pressing"off" dipswitch 23 bit 7 is fuser web count-over stop machine will stop operating when fuser web life is reached if this is set to"1"
Feb 24, 2011 | Office Equipment & Supplies
What SC 541 is ?
sc 541 is a fuser error code. try these steps
press clear mode once
press 107
press clear/stop and hold it untill your screen changes to copy sp mode.
press copy sp on screen
off and on the machine. it shud reset its code. i am a Ricoh tech. email me if you are having difficulty. ronils_singh@yahoo.com.au
Oct 01, 2010 | Ricoh Aficio 450 Copier
How do you store fax numbers
Press
74
set
119
press 1 or 2...... choose 1 touch number
set
stop
Press
72
set
1 for 1 touch numbers
press one of the yellow number keys
enter fax number
set
enter name
set
continue with yellow numbers or press stop when done
Dec 29, 2009 | Panasonic PanaFax UF-8000 Laser Fax
I have functional problem displayed, how can I solve this without paying for a service call
You can try to clear the code by pressing the yellow "clear modes" key, 1, 0, 7, then press and hold the red clear/stop key. Wait for the screen to change, then turn the machine off with the red rocker switch on the left side of the machine, turn back on, and see if that clears the code. If not, let me know what the code is for further assistance.
Oct 22, 2009 | Ricoh Aficio 180 Laser Printer
LEXMARK X63 NOT RECONIZING LEFT CART.
I did find a procedure online to clear the memory and that did the
trick. Here it is, may help someone in the future:
Open lid, take both cartridges out. Physically remove the power cord from outlet or back of unit. While pressing the Stop/Clear button, plug cord back and kee pressing until a message saying "clearing memory" comes on. Reinstall ink. You're done, the message should go away.
May 03, 2009 | Lexmark X63 InkJet Printer
RICOH FT5832 ERROR CODE E-5 47
With the machine on, press clear modes(yellow button), 107, and then hold down clear/stop (red button). Enter 5810 then # key then 1 #. Turn off the main power then power back on. This code is a fuser lamp on condition. It should clear. If not reseat the fuser unit (gets hot), clear using above procedure and try again.
Apr 08, 2009 | Ricoh FT5832 Copier
Copier Ricoh 1232c error code sc517
"yellow clear" then press 1 0 7 and hold down stop.. go into copy sp and enter 7 8 0 7 and then press " # " press the execute button.. when it says done power down from the red switch.. then power back up.. that will clear the error.. but you may need parts if the error returns
Oct 29, 2008 | Office Equipment & Supplies
Brother MFC 3100C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
