My computer had a power outage and now the computer won't turn on. I was told that he was probably my power supply was bad, so I went the Cheap Guys and purchased another power supply and put it in. The light on the computer turns on but nothing else does. The light didn't come on before with the other power supply only with the new one. Please help. Thanks.
I had the exact same thing happen to my gateway, had the graphics card replaced and it ran fine for 3 months and then same thing, shop says possible morherboard problem?
pull the battery out of you motherboard it will reset your bios leave the battery out for a couple minutes then when you put it back in boot up and it should go into bios use your arrows to select set defaults hit enter then reboot it should boot up then if not its possible you have a hard drive issue.
Was this solution helpful? Show your Appreciation by rating it:
I had a an outside breaker blow while my Gateway 506gr was on. Once power was restored all I could get was the colling fans powered on. Had a blank screen and no sounds of the comp trying to rebbot. I did just as James suggested, pulling the battery from the motherboard and re-inserting it after a couple of minutes. The comp was perfect upon restart, I didn't have to do anything further to it, thanks!
