Question about IBM ThinkPad A21m 2628 Notebook
My IBM do not turn on.. IBM A21M..
Just blink the first led left and stop.
Please, help me.
Jose carlos Valle
  • Jose Carlos Valle
    Jose Carlos Valle Jan 03, 2008
    OK thanks, but, that things I did.. I am technician.
    When I turn on the botton switch just the Hard disk blinking and stop. Is dead.
  • Anonymous Jan 07, 2008
    I have the same issue. The power and the HD leds flash, I hear the HD apparently turing on and off. Sometimes I can get to the IBM Logo but soon the laptop dies.
Mine is Thinkpad T40. 5 months ago, it's gone wrong. I removed battery for long time (couple of hours). When I plugged the battery back, and turned on, the fan run well, the power LED and the battery LED lighted, but nothing more. I had to bring it to IBM, they said it was motherboard problem, need 2 weeks and 100$ to fix. While, my friend's laptop (T40p) went wrong too, but he did nothing but left it on his desk for 2 weeks. When I had may T40 back, it worked, but, at the same time, my friend's T40p worked, too, without fixing a thing.
And 2 days ago, I left my T40 without battery or power adapter, once again, it stopped. Exactly the same as the first time. I don't know why. Battery is good, back-up battery is good, too (2.8V). Also, my motherboard is my old one (as before I brought to IBM distributor).
Can anyone explain this? Should I change the motherboard, or fix it, or do nothing as my friend did?
Posted on Jun 10, 2008
I took my laptop to a technician. After a day examining it, he said there was no solution for that problem. Meanwhile I bought a new power cable (not the power adaptor, just the cable from the power outlet to the adaptor). I left my laptop at my shelf for about 3 weeks deciding what to do. When I finally decided, I turned it on (with the new cable) and it is working again without any problem.
Posted on Mar 13, 2008
  • 29 Answers
It sounds as you have motherboard issues. If you turn on and get nothing else, I think you need a motherboard.
1) check battery charge? If you are using a power adaptor is the light staying on when you plug in the adaptor?
If not then the adaptor SOCKET on the motherboard may be loose.
The switch may be faulty also..
If not that...you need a new board I think...and keep reading on here as someone may solve the problem.
    Sergeant:
  • 263 Answers
Check power ac adapter and batery if the batery is ok or charge do a test to the hard drive and memory ram loock on BIOS
Posted on Jan 03, 2008
6ya staff
SOURCE:
How do i connect my ibm thinkpad a21m to the internet
You need the next three letters or numbers after 2628 - ___ Go here http://support.lenovo.com/en_US/downloads/default.page?selector=expand click on laptop and tablets click on thinkpad A series then A21m Then 2628 then the next three then your operating system then voila there you have all your drives and any update for your thinkpad Bookmark so you will always be able to fix what ever may be wrong.. Please rate!!!
Nov 23, 2012 | IBM ThinkPad A21m 2628 Notebook
Power on switch does not light the lcd
am also facing the same problem..with my ibm a21m...still trying to solve it..i try to disconnect the battery and left it for several days..see what happen by this end of the month
Dec 28, 2010 | IBM ThinkPad A21m 2628 Notebook
DEAD ONLY LED BLINKING
change your battery and clean your hardware parts
Sep 26, 2010 | IBM ThinkPad A21m 2628 Notebook
How do you lighten the screen on the ibm a20m laptop computer?
Hello sandee232,
The following key combinations can be used for screen brightness:
•Fn + PgUp Turn the ThinkLight on or off.
•Fn + Home The LCD becomes brighter.
•Fn + End The LCD becomes less bright.
The screen brightness information can be located inthe IBM ThinkPad A21m User guide:
http://safemanuals.com/314159.php?k=c7c8bab9c3a5ec3c048ad8dc9eb006be&ID=321133&q=IBM%20THINKPAD%20A21M
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 04, 2010 | IBM ThinkPad A21m 2628 Notebook
Same exact error here...
just disable the floppy drive through bios
and it's ok
Aug 31, 2009 | IBM ThinkPad A21m 2628 Notebook
Hi: I change the cmos batery to my laptop A21m(2628)and continue working good; then I turn off about two weks but when I tried to turn on...wont'turn on. Just blink the ligth of the HDD and make no noise,...
try to disconnect the power and remove the battery then try to install it bak if it continue to blink try to press and hold on pwer buttom for than 15 sec then try to turn ur laptop again
Jun 09, 2009 | IBM ThinkPad A21m 2628 Notebook
Error code 175
If you have access to the internet another way, search the error code by googling it, or going to the IBM website and searching it anf for solutions.
May 19, 2008 | IBM ThinkPad A21m 2628 Notebook
Bios password
ibm think pad r40 bios password cracker
Oct 11, 2007 | IBM ThinkPad A21m 2628 Notebook
Always shutdown my IBM ThinkPad A21m 2628 PC Notebook
It must be a processor overheating problem, check the vents are not restricted and if the fan is always on or never comes on because of a faulty temp setting then theres a overheating problem and the processor will shut down before any damage.
Oct 02, 2007 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad A21m 2628 Notebook Logo
228 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
