Question about RCA P52939 52" Rear Projection Television
RCA projection tv Model # P52927
Our tv is distorted and the picture is curved. It did it once one morning so I turned it off and back on and it was okay. It did it again, but this time, turning it off won't fix the problem. Any solution?
  • smoke111 Jan 22, 2008
    i read the posting on the hour glass effect, I also have a 52" rca with the same problem.It comes and goes I can solder the conections if I knew where they were exactly. Please tell me wich board I have to re solder.
  • 579 Answers
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it.
Posted on Jan 03, 2008
How do I replace control board?
RCA/Westinghouse HV320WXC1007061 T-Con Boards ...
? 4:35
Jan 21, 2013 - Uploaded by
RCA TV Repair Westinghouse TV Repair T Con Board Tutorial & No Picture ... Top Common LCD TV problems for bad TimingControl T-Con Boards: .... VR-3215 with no picture no sound but the power LED is solid green, any ...
RCA 276046 Power Supply Unit (PSU) Boards ... - YouTube
Nov 24, 2015 | RCA P52927 52" Rear Projection TV
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dark picture
are you using the s-video input
Jan 10, 2009 | RCA P52926 52" Rear Projection Television
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA model P52927
Look, take out back cover and on the bottom left and right side you will see screw (2 or 4), take out it,Disconnect 2 plugs wire from chasis, pull out the box and you will have space for clean your screen.( You will take out all box with main chasis, convergence chasis )
Apr 22, 2008 | RCA P52926 52" Rear Projection Television
RCA model P52927
let me get some info how to get the screen off and I' get back to you... e-mail me
Mar 23, 2008 | RCA P52926 52" Rear Projection Television
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Mar 07, 2008 | RCA P52937 52" Rear Projection Television
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
RCA P52939 52" Rear Projection Television Logo
188 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
