Question about BenQ T705 17" LCD Monitor
Benq LCD monitor
After about 15min of being turned on , it seems to fade and then go completly
to a black screen. The monitor green light is still on. If I shut it off and wait 5 mins I will grt another 10-15 mins before it goes again
  • Streets Jan 11, 2008
    Same problem here,
    It looks like a heat problem.
    After 10-15 minutes the screen has cooled and is functional again.
    Hope to find a solution somewhere
I had same problem. No Power at the monitor. what can I do?
Posted on Jan 15, 2008
How to fix my Benq Monitor which is scrolling full screens of different colours.
all modern LCDs have ONE and ONE only native screen size. since you did not tell us the model number we have to tell you maybe you are setting the wrong size. if the monitor has worked before then you are sending it the wrong signal.
Jul 25, 2016 | BenQ FP91V (Silver, Black) 19 inch LCD...
Black screen
could be a problem graphic card , failing
if you have a plug in card , then reposition the cable back onto the mother board monitor connection to test
Jun 20, 2017 | BenQ G2412HD 23 inch Monitor
My Benq t221w monitors power light flashes green ond will not turn on, the screen stays black, sometimes it will turn on but noe it stays off.
It is an inverter issue, you can seek a replacement but it would be more cost effective to replace the unit.
Mar 14, 2011 | BenQ T221W 22 inch LCD Monitor
Benq T905 Monitor's green light turns on and then off
Check for blown MOSFET IRFU9024N and transistors C5707/5706, and fuse in the inverter circuits section. Also look for bad caps with bulging top/seal. See some pictures of failed Dell monitors (BenQ made alot of monitors for Dell),
Mar 14, 2010 | BenQ T905 (Black, Silver) 19 inch LCD...
Black screen has power
It's seems you got a busted backight inverter. Need to replaced a new one or repaired it... Have a nice day!
Nov 03, 2008 | BenQ FP71E 17" LCD Monitor
White screen
dreaded capacitor issue. benq's were famous for it. if you are handy with disassembly and careful you can take it apart and do it yourself. look for any capacitors with rounded tops. i fixed one ... the part is only two dollars or so but it's a good feeling to know you fixed it instead of tossing it.
Aug 28, 2008 | BenQ FP737S-D 17" LCD Monitor
BenQ fp737 monitor
Disconnect the signal cable from CPU and power on.You should get a BenQ Blue screen.
If no Display,Problem is definitely monitor related ie monitor has a hardware defect most probably the power/invertor board has a few blown components.
If you are technically able,you can dismantle monitor and check components on the Invertor board which you may find on my other posts.
Please reply if you need more help.Please rate this solution.
Aug 25, 2008 | BenQ FP737S-D 17" LCD Monitor
Can repairs be made to BenQ FP731 17 inch Flat Screen.
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Jan 30, 2008 | BenQ FP731 17" LCD Monitor
Monitor turns it self off
exact same thing has happened to me. I have been told it's some part which often burns out on lcd's which can be replaced easily...
Sep 18, 2007 | BenQ FP91G+ 19" LCD Monitor
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
BenQ T705 17" LCD Monitor Logo
319 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
