Question about Panasonic TH-42PHD8UK 42 in. Plasma Television
Loud Fan I have had my Panasonic TH-42PHD8UK for two years and just recently when I turn the TV on, there is a loud fan sound. Wasn't there at first. Everything works great. Just very loud fan sound. Is this normal?
  • Anonymous Mar 25, 2014
    no more details
  • 579 Answers
Yes, fans are somewhat the bane of these new TV technologies. With all the mechanical and optical stuf in them now, TV's are a lot less reliable than the good-ole CRT type.
Fans are easy to replace though.
Posted on Jan 03, 2008
What could be causing loud grinding noise when i switch on aircon? Aircon now not working but only makes loud sound.
Sounds like the bearing or part of the clutch in the A/C compressor has failed, or possibly component on a/c fouling on something due to recent repairs however would be unlikely and probably just a coincidence..
Check A/C compressor turns by hand, should be firm but not make any noises.
Check for fouling components related to a/c compressor clutch.
Feb 12, 2016 | Cars & Trucks
Our Panasonic 50" TH 42PX75U
well it sounds like something fried inside the tv. In my experience, this sounds like your y-sustain board went bad. it could be your video board also. considering todays value of the 50" panasonic plasma, it will be cheaper to replace it, unless you are willing to spend around $300 to get it fix at a shop.
good luck
Jun 17, 2011 | Panasonic TH-42PX75U 42 in. Plasma...
I'm experiencing a loud buzzing (fan?) sound that just started recently while watching my HLP5674W. The picture is fine, but the sound of what may be a fan or something like that is very loud and will...
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner.
Contact local tv repair shop to get color wheel replaced in tv.
Thanks.
Oct 19, 2010 | Samsung HLP5674W 56" Rear Projection...
When I turn on the tv it sounds like a fan has started up. The sound stays there whike th tv is on. When I turn it of it sounds like a fan windind down. I have a 50 inch LG plasma.
ther are at least 2 fans in them some models even more you however should not be hear them loud ther are all running at half power if it is noisey then it will need to be rplaced before it quits altogether then you will loose something else in the set
Dec 03, 2009 | Televison & Video
Outside fan does not spin and a loud screeching sound coming from
Hey there, sounds like the bearings seized in your fan motor. You need to replace the fan motor. If the compressor runs without the fan, th pressures build up and if they reach an extreme point, the compressor will bypass internally, creating a loud sound as the high pressure is released to the low pressure side. I would turn the thermostat on and stand by the outdoor unit as it start. Leave the disconnect on the wall readily available so you can quickly turn it off. If the compressor sounds ok when it starts up and runs for a couple seconds, turn it off right away and replace the fan motor and you should be good to go. If the compressor sounds bad or real noisy immediately at start up, the fan motor not working killed your compreesor. You would need a motor and compressor, might as well replace the unit at this point if you are paying to have it done. Let me know if you need anything else
seth
Jul 03, 2009 | Carrier Heating & Cooling
Loud cooling fan
no its not normal my fried .do not use the tv.if its under warranty get it replaced or repaired at least.as if not under warranty its the problem of either anything blocking the fan to spin properly or the fan motor is turned weak and needs replaced.if used the tv like this without reparing it will damage the other costly parts of the tv later on.
Mar 06, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Laptop Fan Sounds real Loud.
I would either call HP or if you got th extended warranty and go back to the store and have the take care of the repairs so you don't void the warranty. You can tell them the mousepad is worn out and it won't move the mouse properly and also explain about the overheating problem, both should be covered under warranty.
Feb 17, 2009 | Compaq Presario C700T Notebook
Please help
When the red light flashes, it means that something has gone wrong wit h the set internally. The set will have to be taken to a service centre.
May 31, 2008 | Panasonic TH-42PHD8UK 42 in. Plasma...
Panasonic TH-42PHD8UK 42 in. Plasma Television Logo
368 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
