Amana PTH123B25AJ Heat Pump,12000BTU, 230V ,2.5KW PTAC Air Conditioner
Problem for Amana PTH123B25AJ Heat Pump,12000BTU, 230V ,2.5KW PTAC Air...
Wont switch over to heat
By glenstanford on Oct 31, 2009
wont switch over to heat
Solution #1
posted on Nov 03, 2009
Not Rated)
frankrhoney
Rank: Guru  Air Conditioners  Expert
Rating: 90%, 17 votes
You probably have a bad coil on the reversing valve
Was this helpful?
Yes
No
Popular Solutions for Amana PTH123B25AJ Heat
Questions and Unsolved Problems for Amana PTH123B25AJ Heat
Do you recommend Amana PTH123B25AJ Heat Pump,12000BTU, 230V ,2.5KW PTAC Air Conditioner?
Answer
Answer
My 4yr old Amana heat pump quit working - the thermostat display was blank. I replaced the... (More)
Answer
Is there such thing like a kit to convert amana ptac wall unit to work on my existing hard wire wall... (More)
Answer
i'm running 48 units motel. Only one Amana A/C is condensing lot of water.Can somebody explain?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
